Why is my surface finish comically bad?
Posted by mpk23
July 21, 2015 04:23PM
Hello,
I'm printing with a Simple Metal fitted with an E3D v6, 0.4 nozzle. Been printing for seven months.
I've been mostly printing with Cura, but I saw the new version pop up, so I thought I'd see if I could get better results on some of the Make: shootout parts using Slic3r.
The results are more poor than I could have imagined - I'm using the same speeds, retraction, temps, and such in both slicers, so I was hoping someone could identify the culprit from the image attached. Slic3r is the left print, Cura on the right.
I used Slic3r when I first started for quite a while, and always got better results than this...
Unrelated, but 'Export .Gcode' doesn't seem to actually create a file in my target folder, even though I can see the 'ghost' of the exported file in the folder when I try to export again. Send to Octoprint printer works fine, so I could download the gcode to show the settings section:
Following is the relevant bits, I can post some code too if needed.
Thanks in advance for the knowledgable eyes! I'm looking forward to getting back into Slic3r! I hope I haven't violated too many forum rules and norms....
-Matt
; generated by Slic3r 1.2.9 on 2015-07-21 at 13:31:06
; external perimeters extrusion width = 0.40mm
; perimeters extrusion width = 0.67mm
; infill extrusion width = 0.67mm
; solid infill extrusion width = 0.67mm
; top infill extrusion width = 0.67mm
//Large amount of gcode
; filament used = 3976.1mm (9.1cm3)
; avoid_crossing_perimeters = 0
; bed_shape = 0x0,150x0,150x150,0x150
; bed_temperature = 55
; before_layer_gcode =
; bridge_acceleration = 750
; bridge_fan_speed = 100
; brim_width = 2
; complete_objects = 0
; cooling = 1
; default_acceleration = 600
; disable_fan_first_layers = 2
; duplicate_distance = 6
; end_gcode = M104 S0 ; turn off temperature\nG28 X0  ; home X axis\nM84     ; disable motors\n
; extruder_clearance_height = 20
; extruder_clearance_radius = 20
; extruder_offset = 0x0
; extrusion_axis = E
; extrusion_multiplier = 1
; fan_always_on = 0
; fan_below_layer_time = 100
; filament_colour = #FFFFFF
; filament_diameter = 1.71
; first_layer_acceleration = 450
; first_layer_bed_temperature = 60
; first_layer_extrusion_width = 105%
; first_layer_speed = 30
; first_layer_temperature = 212
; gcode_arcs = 0
; gcode_comments = 1
; gcode_flavor = reprap
; infill_acceleration = 750
; infill_first = 0
; layer_gcode =
; max_fan_speed = 100
; max_print_speed = 80
; max_volumetric_speed = 0
; min_fan_speed = 95
; min_print_speed = 10
; min_skirt_length = 0
; notes =
; nozzle_diameter = 0.4
; only_retract_when_crossing_perimeters = 1
; ooze_prevention = 0
; output_filename_format = [input_filename_base].gcode
; perimeter_acceleration = 450
; post_process =
; pressure_advance = 0
; resolution = 0
; retract_before_travel = 2
; retract_layer_change = 0
; retract_length = 2.5
; retract_length_toolchange = 10
; retract_lift = 1
; retract_restart_extra = 0
; retract_restart_extra_toolchange = 0
; retract_speed = 40
; skirt_distance = 6
; skirt_height = 1
; skirts = 2
; slowdown_below_layer_time = 10
; spiral_vase = 0
; standby_temperature_delta = -5
; start_gcode = G28 ; home all axes\nG29; Level Bed\nG1 Z5 F5000 ; lift nozzle\n
; temperature = 210
; threads = 2
; toolchange_gcode =
; travel_speed = 130
; use_firmware_retraction = 0
; use_relative_e_distances = 0
; use_volumetric_e = 0
; vibration_limit = 0
; wipe = 1
; z_offset = 0
; dont_support_bridges = 1
; extrusion_width = 0
; first_layer_height = 0.35
; infill_only_where_needed = 0
; interface_shells = 0
; layer_height = 0.2
; raft_layers = 0
; seam_position = aligned
; support_material = 0
; support_material_angle = 0
; support_material_contact_distance = 0.2
; support_material_enforce_layers = 0
; support_material_extruder = 1
; support_material_extrusion_width = 0
; support_material_interface_extruder = 1
; support_material_interface_layers = 3
; support_material_interface_spacing = 0
; support_material_interface_speed = 100%
; support_material_pattern = rectilinear
; support_material_spacing = 2.5
; support_material_speed = 60
; support_material_threshold = 0
; xy_size_compensation = 0
; bottom_solid_layers = 3
; bridge_flow_ratio = 1
; bridge_speed = 60
; external_fill_pattern = rectilinear
; external_perimeter_extrusion_width = 0
; external_perimeter_speed = 70%
; external_perimeters_first = 0
; extra_perimeters = 1
; fill_angle = 45
; fill_density = 10%
; fill_pattern = honeycomb
; gap_fill_speed = 20
; infill_every_layers = 1
; infill_extruder = 1
; infill_extrusion_width = 0
; infill_overlap = 15%
; infill_speed = 60
; overhangs = 1
; perimeter_extruder = 1
; perimeter_extrusion_width = 0
; perimeter_speed = 60
; perimeters = 3
; small_perimeter_speed = 15
; solid_infill_below_area = 70
; solid_infill_every_layers = 0
; solid_infill_extruder = 1
; solid_infill_extrusion_width = 0
; solid_infill_speed = 30
; thin_walls = 1
; top_infill_extrusion_width = 0
; top_solid_infill_speed = 15
; top_solid_layers = 3
Edited 1 time(s). Last edit at 07/21/2015 04:24PM by mpk23.
Re: Why is my surface finish comically bad?
July 21, 2015 04:54PM
Okay, I'm seeing now that it's likely a nasty bug in 1.2.9 stable, so I'm going to try again with 1.2.7B and see if I can get the precision I remember.
Thanks again!
