[SOLVED] Auto Bed Levelling Isn't correcting Enough! September 25, 2014 05:09PM |
Re: Why Is Slic3r Doing This To Me? September 25, 2014 05:23PM |
Re: Why Is Slic3r Doing This To Me? September 25, 2014 05:36PM |
3Dmaker4U
Are you sure that the problem is with Slic3r? Load your gcode file here: [gcode.ws] and look at the layers in the "affected" region.
If it looks ok, meaning there are no such errors like those you see in the print, then it might be a sign of underextrusion.
If there are errors in the file, might be that the "complex" model has some errors that Slic3r could not repair.
Re: Why Is Slic3r Doing This To Me? September 26, 2014 08:20AM |
Re: Why Is Slic3r Doing This To Me? September 26, 2014 08:40AM |
Floyd
Just after your G28 to home you place the G29 for ABL and you are done.
Re: Why Is Slic3r Doing This To Me? September 26, 2014 10:31AM |
Re: Why Is Slic3r Doing This To Me? September 26, 2014 11:26AM |
dmould
Simply add your auto-level instruction to the custom start code of any slicer and it should work. G-code files usually compress very well, so just ZIP them before attaching and they should not be over the file size limit.
Dave
Re: Why Is Slic3r Doing This To Me? September 26, 2014 02:32PM |
dailafing
dmould
Dave
I tried zipping it, just over 2mb... So was still too big....
I'm currently trying to get my auto levelling probe to work at all now :p
Its making Z correctings for the bed, but the corrections are no correct... Its 'over correcting'... So in some areas of the bed its right, and in others its not right....
Re: Why Is Slic3r Doing This To Me? September 26, 2014 03:57PM |
You place it under the start G-code area in Cura and it should be the line after the G28.Quote
dailafing
Hi Floyd, I tried placing G29 in the code but when sliced with cura, it didn't skew while traveling X/Y.
Also, what's this ABL you speak of?
Perhaps you could post specific instructions, and I'll let you know the results.
Re: Why Is Slic3r Doing This To Me? September 26, 2014 05:54PM |
Re: Why Is Slic3r Doing This To Me? September 27, 2014 01:08PM |
Re: Why Is Slic3r Doing This To Me? December 24, 2014 06:26PM |
Re: Why Is Slic3r Doing This To Me? December 31, 2014 11:40AM |
Re: Why Is Slic3r Doing This To Me? December 31, 2014 12:18PM |
Re: [SOLVED] Auto Bed Levelling Isn't correcting Enough! June 15, 2015 01:39AM |
Re: [SOLVED] Auto Bed Levelling Isn't correcting Enough! June 18, 2015 01:48PM |
Re: [SOLVED] Auto Bed Levelling Isn't correcting Enough! June 18, 2015 03:56PM |
Kafledelius
Bumping a really old thread here, sorry..
I am having the same issue as dc42 and p3d.. Did you guys find a solution?
My printer prints too high on one side, no matter what i do. I have tried to manually level the bed, tilt the bed a lot (tested the abl), recalibrating Steps per mm, and a few other things.
- Please help ?
Re: [SOLVED] Auto Bed Levelling Isn't correcting Enough! November 14, 2015 01:48PM |
