Error on line 236
Posted by spaceman
Error on line 236
July 28, 2012 10:50AM
Hello
When I try to use the latest Dev version from Github, I get this error message when exporting Gcode:
Can't call method config on an undefined value at C:/dev/CitrusPerl/Slic3r/lib/Slic3r/GUI/SkeinPanel.pm on line 236.
Can anyone tell me what I have done wrong?
FOOTNOTE:
Would it be too much to ask if a timestamp could be added to the developement version so we can be more precise when referencing which version we have.
EDIT: We have discovered that we can quick slice with our own config settings but cannot use the "Export Gcode" button to create the Gcode. I'm guessing it is a GUI panel issue.
Edited 1 time(s). Last edit at 07/28/2012 11:07AM by spaceman.
Re: Error on line 236
July 28, 2012 08:39PM
Roll back to one commit before Allesandro's July 27 commit. This work for me. The bug report also states that turning off multiple processors may help//?
-Rob A.
July 28, 2012 10:24PM
Hi Rob,
I'm just learning to get around in Github. Can you walk me thru how to 'Roll Back'
July 30, 2012 11:40AM
It depends on the OS. I'm using GIT for windows, and in that GUI I just click on the version I want. I then have to discard changes since that version and I'm back to the old one...
If using git from the command prompt I'd suggest google, which gave me:
[stackoverflow.com]
-Rob A>
July 30, 2012 07:18PM
Hi RobA
Thanks for the response. I figured out how to get the GUI running for Git for Windows (a small step it seems). But that has just opened more questions.
I guess because you have been using Git-GUI for all your clones, your local repository contains all the old versions. I'm guessing that's why you can just click on whatever version you want. I don't have that option because this is my first time using Git-GUI. What I can't seem to figure out is how to remote clone an older version. In Git-GUI window I clicked "repository" then clicked "visualize master's history" and can see all the older versions in the GitK window. I just can't figure out how to clone them to my local repository. confused smiley
Do you have any ideas?
