Slic3r build problem!
August 03, 2012 02:08PM
Hey
I have tried to get the newest version 0.8.5 DEV to build on my machine, but after I have installed Citrusperl (same problem for strawberry perl)
I come to the part where I need to do the following:
https://github.com/alexrj/Slic3r/wiki/Running-Slic3r-from-git-on-Windows
cpan JSON App::cpanminus
cpanm [github.com]
(The above is to install a custom Math::Libm build, because one of the function is undefined in the MinGW math libarary)
cpanm Moo Math::Clipper Math::Geometry::Voronoi Boost::Geometry::Utils Class:angry smileySAccessor Math::ConvexHull Math:tongue sticking out smileylanePath
The second line dosnt work, I get the following output in the terminal:
C:\Users\B4Me\Documents\GitHub\Slic3r>cpanm [github.com]
tarball/master
--> Working on [github.com]
Fetching [github.com] ... OK
/usr/bin/tar: pax_global_header: Unknown file type 'g', extracted as normal file
! Bad archive: master
! Failed to unpack master: no directory
! Failed to fetch distribution
How can I fix this ?
Re: Slic3r build problem!
August 03, 2012 07:44PM
Or maybe if one could give a link to a zip of the build version 0.8.5 dev ? (if someone have it build and ready to share with me )
August 03, 2012 11:46PM
Did you download MinGW and set GCC properly?
August 04, 2012 03:45AM
Yes, yes I did, for citrusPerl I ran the utility and downloaded MinGW
installed it as C:/mingw32
pointed then to that folder..
But thats NOT the issue is it ?
I got this error as mentioned in main post:
When I add the custom library
