I tried to print with 0.90 with no luck, it is waiting for agessss , my last test was to wait until the print begin.... well i'm still waiting ( 45 minutes now )
here is my test procedure
1) start pronterface, set temp of extruder(240) and bed(108), and wait until the temp is reached
2) verify that slic3r is set to 240 extrusion and bed set at 108. Export config.ini
3) Load a stl
4) verified the gcode
5) click print, and wait...wait......wait.............................
oh btw, i'm with teacup firmware,
I executed the same test under 0.8.4, with no issue.
here the gcode
; generated by Slic3r 0.9.0 on 2012-08-09 at 22:09:59
; layer_height = 0.20
; perimeters = 3
; solid_layers = 3
; fill_density = 1
; perimeter_speed = 55
; infill_speed = 50
; travel_speed = 200
; scale = 1
; nozzle_diameter = 0.30
; filament_diameter = 2.84
; extrusion_multiplier = 1
; single wall width = 0.37mm
M109 P1 S108 ; wait for bed temperature to be reached
M104 S240 ; set temperature
G28 ; home all axes
M109 S240 ; wait for temperature to be reached
G90 ; use absolute coordinates
G21 ; set units to millimeters
G1 Z0.200 F12000.000
G1 X75.600 Y88.545
Edited 2 time(s). Last edit at 08/09/2012 11:03PM by Carignan.
