Hi All, Got a strange question about dual extrusion in Slic3r. I'm running 1.2.9 on MacOS and trying to set up dual extrusion. I'm relatively new to Slic3r having used Cura a lot in the past, however Cura doesn't seem to properly support dual extrusion on custom machines as of the current version.
I have configured my filament in Slic3r at First Layer 210, bed 60, other layers the same. Ooze prevention is on at -20 degree temperature delta.
Basically Extruder 0 is printing at 210 as expected, Extruder 1 is printing at 200
For reasons I'm trying to work out, the GCode starts:
M190 S60 ; set bed temperature
M104 S190 T0 ; set temperature
M104 S180 T1 ; set temperature
Then once each tool is selected as active during the gcode, T0 always heats to 210 (as expected) however when T1 is selected, it only heats to 200!!
It's driving me nuts. I wanted to check if it's user stupidity, or a bug before I submit anything.
Cheers
Matthew
