Slicer 0.9.1 - retracts during infill ?
Posted by Emmanuel
August 23, 2012 05:48AM
Wonder if other are having the same thing ?
I don't remember to have that before, but even if I set 2 to 2,5mm of minimum travel after retraction, the extruder is still retracting almost all the time between two strands of the same infill.
Skeinforge have a "no retract in the same island" by default that I miss here : /
[edit]: I commented the same on the issue#29 about that
Edited 1 time(s). Last edit at 08/23/2012 06:04AM by Emmanuel.
Re: Slicer 0.9.1 - retracts during infill ?
August 23, 2012 06:21AM
Emmanuel
Ah, this feature is actually working ? I had the vague memory of it not doing anything, I'll have to try again.
September 05, 2012 01:33PM
In the link you will find the guide written by me and Lorenzo Cantini of Kent’s strapper for Slic3r.
[www.ivanbortolin.it]
Edited 1 time(s). Last edit at 09/05/2012 04:39PM by Ivan Bortolin.
