"Fan will be turned off" doesn't actually stop the cooling fan(s) confused smiley
Posted by flotul
December 26, 2017 02:26PM
Hello there,
Having some problems with large parts to print (warping issue), I tried to stop the cooling fans (I've a WitBox 1, cooling 2 fans in the back).
So, in Filament Settings > Cooling, I unchecked:
- "Keep fan always on"
- "Enable auto cooling"
I was thinking this would completely stop all my fans but the extruder's one. But it doesn't.
Looking at the Gcode, I can see that the M106 command is still issued.
I "manually" modify the "M106 S255" command to "M107" in the Gcode file, the cooling fans will stay stopped.
Am I missing some setting or not understanding something?
Edited 2 time(s). Last edit at 12/26/2017 02:50PM by flotul.
Roger
WitBox 1 / SketchUp / Slic3r 1.2.9
Re: "Fan will be turned off" doesn't actually stop the cooling fan(s) confused smiley
December 26, 2017 04:46PM
check in the printer settings tab-custom gcode, maybe you have a M106 command in there
December 28, 2017 11:45AM
Thanks Obewan,
You're right, it was there winking smiley
Roger
