I used replicatorG windows version and simply downloaded the pre-build slic3r as the slice engine.
The combination works well till the version 0.9.1. But when the ver 0.9.2 is out. I got the following error
Can't locate object method "add_object_from_file" via package "Slic3r:
rint" at
d:/ReplicatorG/replicatorg-0039/skein_engines/slic3r_engines/windows/lib/std/cavaexecscript/slic3r-console.pl line 86.
I have try to run the slic3r-console.exe directly on cmd line window and got the similiar error with any file parameters.
The version 0.9.3 have the same problem. Does anyone know what's happened here?
Add:
Just simply input "slic3r-console model.stl" in cmd line window and it dosen't work ( ver 0.9.1 works perfectly)
Anyone have a successful running of new version slic3r-console.exe? BTW, I used win-32 bit version
Edited 1 time(s). Last edit at 10/08/2012 09:21PM by shaqiu.
