I am trying to print the Vertical Prusa X-Axis from Thingiverse and Slic3r is not filling in the bottom 2 layers correctly, it is also not producing lines that extend to circles.
It is calibrated correctly as a 0.5mm thin walled object is coming out at 0.57 - 0.6 which a) is fairly close, b) larger than required so the interline spacing should be less.
You can see in the attached photo that the solid fill on the the first 2 layers is not solid, the perimeters does not meet the infill and the infil does not meet the circles.
Which parameters should I play with to reduce this, or is it a bug?
Cheers
Geoff
Edited 2 time(s). Last edit at 11/15/2012 05:30PM by geoffd.
