Check my stl for me?
Posted by tmorris9
November 15, 2012 06:13PM
So I have an object I made in Lightwave 3D and it says it's manifold. I load it into meshlab and it says it has zero non manifold edges or vertices, yet slicer (0.7.2 & 0.9.5) say it's non manifold and end up slicing it wrong.
It's a box with holes on all 6 sides but slicer fills in the sides and only leaves the top and bottom open. I will attach the stl and jpg of what the model should look like
open | download - Cabinet1.stl (89.5 KB)
open | download - Screen shot 2012-11-15 at 3.06.02 PM.jpg (119.9 KB)
Re: Check my stl for me?
November 15, 2012 06:50PM
I have you File repair, now it works
Repaired File
Hardwarekiller
November 15, 2012 08:47PM
Thank you.
Can you tell me what was wrong and how you fixed it?
I need to learn for future problems.
Thanks!
November 16, 2012 10:22AM
Your files have holes in the surface as diagnosed using netfabb studio basic (which can also be used to repair it).
