Unable to slice in 0.9.5 and 0.9.7
Posted by jon_bondy
December 29, 2012 11:30PM
I have tried to slice the anulus.stl file from [www.thingiverse.com] using both 0.9.5 and 0.9.7. I cleaned the STL file up using the offline version of NetFabb Basic (which usually helps quite a lot), but it did not help this time. I get to the Infilling stage, after which, it just sits there until I kill it.
Edited 1 time(s). Last edit at 12/29/2012 11:38PM by jon_bondy.
Re: Unable to slice in 0.9.5 and 0.9.7
December 31, 2012 08:07AM
Can you export your config (using the "Export Config..." menu item) and post it here so that we can reproduce your problem?
December 31, 2012 09:04AM
Here you go! Thanks!
open | download - config.ini (2.9 KB)
