programa Slic3R en español
January 11, 2013 04:55AM
Hola, sabeis si este programa Slic3r Version: 0.8.4 esta en español?
Re: programa Slic3R en español
January 11, 2013 05:33PM
I know nothing about a Spanish version but I would like to point out that version 0.8.4 is one of the worst possible Slic3r versions to use as it adds 0.1mm to all walls in X and Y. I would suggest Kisslicer or Cura and if you insist on using Slic3r use version 0.7.2b
