I'm running 9.8 right now but this is an issue I've had for many previous versions as well.
When I go in the
Print Settings > Layers and Perimeters settings and try and set the number of perimeters, top layers, and bottom layers, then save the setting, the change doesn't always take. I normally only see the problem when I'm changing the values from 2 to 3, but if I change from 2 to 1, 1 to 3, 3 to 4, 4 to 3, I don't normally see the problem. I haven't tested enough cases to pinpoint what is in error, but needless to say it is a very annoying issue becuase sometimes I don't catch it.
Anybody else having these issues? I'm running the x86 program on Windows 7.
