I'm using Slic3r 0.9.8 on several PCs, synced with Dropbox (so there is always the same config on any PC)
However, the way slic3r 0.9.8 use this config files makes this to not work properly, as the config files are saved in a local directory, outside of my dropbox folder.
So my question is : is there any way to set the config dir ?
In earlier version, there is a --load parameter, but it seems to work only for the "old" unique config.ini file
Cheers!
Gege
innocuousprototypes.gege2b.info]
