Hello,
i have a problem with parts that have holes for nuts or other inner features.
When i print the calibration thing (part with some holes) [
www.thingiverse.com] and measure the diameter of the holes they are all a bit to small. The smaller the hole nominal diameter the bigger is the error.
The extruder steps / filament diameter... are all set correctly everything else is fine.
When i now adjust the perimeter width in the advanced settings to 110% the holes get even smaller, when i set it to 90% they get smaller as well. If you look at the g-code in a viewer it can be seen that the inner perimeter of the hole moves torwards the center in both cases with 110% and 90%.
Anyone else having thins problem?
my projects: [
www.robotik.dyyyh.de] ...
