Slicer couldn't generate the correct gcode for this part
Posted by ChiaT
April 25, 2013 06:26PM
Hey Guys!
So I need to print a part for someone. It is some kind of z-axis stabilizer. (see attached stl and gcode)
[www.dropbox.com] ... part.gcode
[www.dropbox.com]
For some reason, the slicer couldn't make one of the hole, and the printed part has half a hole on it...
[i.imgur.com]
What kind of problem is this?
I did kind of solve it by reorienting the part, but I would like to know if there is a way to solve this problem.
I am using 0.9.8
Re: Slicer couldn't generate the correct gcode for this part
April 26, 2013 01:34AM
I loaded it into Solidworks, resaved it as an STL, and Solidworks said that it cannot save it as an STL because the geometry type is not STL compatible. I think there is something wrong with your STL file.
By the way, Slic3r 0.99 also showed 1/2 a lower cutout.
[www.matter-replicator.com]
April 26, 2013 06:43AM
What's happened is the STL is non-manifold (so not an unambigous 3d shape), so slic3r can't know what to do with it. You can run broken stls through cloud.netfabb.com to clean them up.
April 26, 2013 11:52AM
WOW!! Thanks james glanville smiling smiley
The STL is now fixed and gcode looks okay!
