Slic3r error
June 08, 2013 03:10PM
In previous post things became a little disjointed, so Im starting over making the problem more simplified.
I can navigate to the Slic3r folder and try to run slic3r and get the following error. Like I said Im a total noob so please be explicate with any helps, thanks.
dave@ubuntu-desktop:~/reprap/Software-master/slic3r$ ./slic3r.pl
Can't locate Boost/Geometry/Utils.pm in @INC (@INC contains: /home/dave/reprap/Software-master/slic3r/lib /etc/perl /usr/local/lib/perl/5.14.2 /usr/local/share/perl/5.14.2 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.14 /usr/share/perl/5.14 /usr/local/lib/site_perl .) at /home/dave/reprap/Software-master/slic3r/lib/Slic3r.pm line 32.
BEGIN failed--compilation aborted at /home/dave/reprap/Software-master/slic3r/lib/Slic3r.pm line 32.
Compilation failed in require at ./slic3r.pl line 16.
BEGIN failed--compilation aborted at ./slic3r.pl line 16.
Re: Slic3r error
June 08, 2013 03:33PM
So then I tried:
sudo cpanm Boost::Geometry::Utils Math::Clipper \
Math::ConvexHull Math::ConvexHull::MonotoneChain Math::Geometry::Voronoi Math:tongue sticking out smileylanePath Moo Wx XML:confused smileyAX
and end up with:
--> Working on Boost::Geometry::Utils
Fetching [www.cpan.org] ... OK
Configuring Boost-Geometry-Utils-0.13 ... OK
==> Found dependencies: ExtUtils::Typemaps:grinning smileyefault
--> Working on ExtUtils::Typemaps:grinning smileyefault
Configuring ExtUtils-Typemaps-Default-1.03 ... OK
Found ExtUtils::Typemaps 3.18 which doesn't satisfy 3.18_03.
! Installing the dependencies failed: Installed version (3.18) of ExtUtils::Typemaps is not in range '3.18_03'
! Bailing out the installation for ExtUtils-Typemaps-Default-1.03. Retry with --prompt or --force.
! Installing the dependencies failed: Module 'ExtUtils::Typemaps:grinning smileyefault' is not installed
! Bailing out the installation for Boost-Geometry-Utils-0.13. Retry with --prompt or --force.
--> Working on Math::Clipper
Configuring Math-Clipper-1.22 ... OK
! Bailing out the installation for Math-Clipper-1.22. Retry with --prompt or --force.
Math::ConvexHull is up to date. (1.04)
Math::ConvexHull::MonotoneChain is up to date. (0.01)
Math::Geometry::Voronoi is up to date. (1.3)
Math:tongue sticking out smileylanePath is up to date. (104)
Moo is up to date. (1.002000)
Wx is up to date. (0.9922)
XML:confused smileyAX is up to date. (0.99)
So I went cpan.org/~smueller/ExtUtils-ParseXS/ and downloaded ExtUtils-ParseXS-3.18_03, but when I try to extract it it tells me it doesnt look a tar archive and aborts.
Am I on the right track and what am I missing here,please?
Re: Slic3r error[Solved]
June 08, 2013 09:58PM
OMG yes it works!
For those with the same problem, delete all files and folders, or rename containing slic3r.
Then follow source download instructions here:
http://slic3r.org/download
ignore the part underneath that talks about installing other crap first. Just do the top four lines and it works, installs everything checks everything.
When your finished you can enter slic3r with ./slic3r.pl and it will work!
