Custom speed first layer *infill* to prevent distortion August 02, 2013 03:43PM |
Re: Custom speed first layer *infill* to prevent distortion August 06, 2013 03:42AM |
Re: Custom speed first layer *infill* to prevent distortion August 09, 2013 05:04PM |
Re: Custom speed first layer *infill* to prevent distortion August 10, 2013 04:45AM |
Re: Custom speed first layer *infill* to prevent distortion August 11, 2013 08:04AM |
Re: Custom speed first layer *infill* to prevent distortion August 12, 2013 06:19PM |
I'm sorry for the confusion and yes indeed that is what I meant; the first solid layer.Quote
waitaki
The first layer has no infill, its a solid layer - is that what you are referring to?
That is exactly the thing I wanted to avoid. I have tried many different filaments from different suppliers and while most print perfectly fine, there are some, especially black, that behave a bit different then others. In this case I'm referring to black PLA filament which I can get to create a nice thick first perimeter, but looses it's cool (pun intended) when creating the first solid layer within the first perimeter. And I think this is caused by the slow movement of the head that heads up the layer. Speeding up the first solid layer would solve that, but that would also speed up my first perimeters and that won't stick and results more than often in a failed print.Quote
Sound
Personally, I set the First Layer Speed option to 30mm/s ... regardless of things being perimeter, infill or anything else
Sound
I'd put more effort into describing and discussing the problem before coming to a proposed solution.
Re: Custom speed first layer *infill* to prevent distortion September 08, 2013 09:22PM |
