Problems running slic3r on CentOS 6.4 x64 August 07, 2013 05:28AM |
[root@centos64 Slic3r]# perl ./Build.PL App::cpanminus is up to date. (1.6939) --> Working on Boost::Geometry::Utils Fetching [www.cpan.org] ... OK ==> Found dependencies: Module::Build::WithXSpp, ExtUtils::CppGuess, Module::Build --> Working on Module::Build::WithXSpp Fetching [www.cpan.org] ... OK ==> Found dependencies: Module::Build --> Working on Module::Build Fetching [www.cpan.org] ... OK ==> Found dependencies: Module::Build Configuring Module-Build-0.4007 ... OK ==> Found dependencies: Test::More --> Working on Test::More Fetching [www.cpan.org] ... OK Configuring Test-Simple-0.98 ... OK Building and testing Test-Simple-0.98 ... OK Successfully installed Test-Simple-0.98 Building and testing Module-Build-0.4007 ... OK Successfully installed Module-Build-0.4007 (upgraded from 0.35) Configuring Module-Build-WithXSpp-0.13 ... OK ==> Found dependencies: ExtUtils:arseXS, ExtUtils::CppGuess --> Working on ExtUtils:
arseXS Fetching [www.cpan.org] ... OK Configuring ExtUtils-ParseXS-3.18 ... OK Building and testing ExtUtils-ParseXS-3.18 ... OK Successfully installed ExtUtils-ParseXS-3.18 (upgraded from 2.2203) --> Working on ExtUtils::CppGuess Fetching [www.cpan.org] ... OK Configuring ExtUtils-CppGuess-0.07 ... OK Building and testing ExtUtils-CppGuess-0.07 ... FAIL ! Installing ExtUtils::CppGuess failed. See /root/.cpanm/work/1375866935.2077/build.log for details. Retry with --force to force install it. ! Installing the dependencies failed: Module 'ExtUtils::CppGuess' is not installed ! Bailing out the installation for Module-Build-WithXSpp-0.13. ! Installing the dependencies failed: Module 'Module::Build::WithXSpp' is not installed, Module 'ExtUtils::CppGuess' is not installed ! Bailing out the installation for Boost-Geometry-Utils-0.15. 3 distributions installed Class:
SAccessor is up to date. (1.18) Encode::Locale is up to date. (1.03) skipping R/RJ/RJBS/perl-5.18.0.tar.bz2 File:
pec is up to date. (3.40) Getopt::Long is up to date. (2.41) Growl::GNTP is up to date. (0.20) IO:
calar is up to date. (2.110) --> Working on Math::Clipper Fetching [www.cpan.org] ... OK ==> Found dependencies: Module::Build::WithXSpp, ExtUtils::CppGuess --> Working on Module::Build::WithXSpp Fetching [www.cpan.org] ... OK Configuring Module-Build-WithXSpp-0.13 ... OK ==> Found dependencies: ExtUtils::CppGuess --> Working on ExtUtils::CppGuess Fetching [www.cpan.org] ... OK Configuring ExtUtils-CppGuess-0.07 ... OK Building and testing ExtUtils-CppGuess-0.07 ... FAIL ! Installing ExtUtils::CppGuess failed. See /root/.cpanm/work/1375866981.6296/build.log for details. Retry with --force to force install it. ! Installing the dependencies failed: Module 'ExtUtils::CppGuess' is not installed ! Bailing out the installation for Module-Build-WithXSpp-0.13. ! Installing the dependencies failed: Module 'Module::Build::WithXSpp' is not installed, Module 'ExtUtils::CppGuess' is not installed ! Bailing out the installation for Math-Clipper-1.22. Math::ConvexHull::MonotoneChain is up to date. (0.01) Math::Geometry::Voronoi is up to date. (1.3) Math:
lanePath is up to date. (108) Moo is up to date. (1.003000) Scalar::Util is up to date. (1.30) Storable is up to date. (2.45) Test::More is up to date. (0.98) Time::HiRes is up to date. (1.9725) XML:
AX::ExpatXS is up to date. (1.33) --> Working on SMUELLER/ExtUtils-ParseXS-3.18_04.tar.gz Fetching [www.cpan.org] ... OK Configuring ExtUtils-ParseXS-3.18_04 ... OK Building and testing ExtUtils-ParseXS-3.18_04 ... OK Successfully installed ExtUtils-ParseXS-3.18_04 1 distribution installed --> Working on ./xs Configuring /root/Slic3r/xs ... N/A ! Configure failed for ./xs. See /root/.cpanm/work/1375866989.6747/build.log for details. [root@centos64 Slic3r]#
panm (App::cpanminus) 1.6939 on perl 5.010001 built for x86_64-linux-thread-multi Work directory is /root/.cpanm/work/1375866935.2077 You have make /usr/bin/make You have LWP 5.833 You have /bin/tar: tar (GNU tar) 1.23 Copyright (C) 2010 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later [gnu.org]. This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. Written by John Gilmore and Jay Fenlason. You have /usr/bin/unzip Searching Boost::Geometry::Utils on cpanmetadb ... --> Working on Boost::Geometry::Utils Fetching [www.cpan.org] -> OK Unpacking Boost-Geometry-Utils-0.15.tar.gz Entering Boost-Geometry-Utils-0.15 Checking configure dependencies from META.json Checking if you have Module::Build::WithXSpp 0.10 ... No Checking if you have ExtUtils::CppGuess 0.07 ... No Checking if you have Module::Build 0.38 ... No (0.35 < 0.38) ==> Found dependencies: Module::Build::WithXSpp, ExtUtils::CppGuess, Module::Build Searching Module::Build::WithXSpp on cpanmetadb ... --> Working on Module::Build::WithXSpp Fetching [www.cpan.org] -> OK Unpacking Module-Build-WithXSpp-0.13.tar.gz Entering Module-Build-WithXSpp-0.13 Checking configure dependencies from META.json Checking if you have Module::Build 0.26 ... Yes (0.35) Checking if you have Module::Build 0.36 ... No (0.35 < 0.36) ==> Found dependencies: Module::Build Searching Module::Build on cpanmetadb ... --> Working on Module::Build Fetching [www.cpan.org] -> OK Unpacking Module-Build-0.4007.tar.gz Entering Module-Build-0.4007 Checking configure dependencies from META.json Checking if you have Module::Build 0.36 ... No (0.35 < 0.36) ==> Found dependencies: Module::Build Already tried Module::Build. Skipping. Configuring Module-Build-0.4007 Running Build.PL Checking prerequisites... build_requires: ! Test::More is not installed ERRORS/WARNINGS FOUND IN PREREQUISITES. You may wish to install the versions of the modules indicated above before proceeding with this installation Created MYMETA.yml and MYMETA.json Creating new 'Build' script for 'Module-Build' version '0.4007' -> OK Checking dependencies from MYMETA.json ... Checking if you have Module::Metadata 1.000002 ... Yes (1.000014) Checking if you have File:pec 0.82 ... Yes (3.40) Checking if you have ExtUtils::Install 0 ... Yes (1.54) Checking if you have File::Compare 0 ... Yes (1.1006) Checking if you have File::Find 0 ... Yes (1.14) Checking if you have CPAN::Meta 2.110420 ... Yes (2.132140) Checking if you have File:
ath 0 ... Yes (2.08) Checking if you have Perl::OSType 1 ... Yes (1.003) Checking if you have ExtUtils::Manifest 0 ... Yes (1.56) Checking if you have ExtUtils::CBuilder 0.27 ... Yes (0.27) Checking if you have Getopt::Long 0 ... Yes (2.41) Checking if you have File::Copy 0 ... Yes (2.14) Checking if you have Parse::CPAN::Meta 1.4401 ... Yes (1.4405) Checking if you have Test::Harness 3.16 ... Yes (3.17) Checking if you have Text::Abbrev 0 ... Yes (1.01) Checking if you have ExtUtils:
arseXS 2.21 ... Yes (2.2203) Checking if you have Data:
umper 0 ... Yes (2.124) Checking if you have version 0.87 ... Yes (0.9902) Checking if you have Pod::Man 2.17 ... Yes (2.22) Checking if you have CPAN::Meta::YAML 0.003 ... Yes (0.008) Checking if you have Test::More 0.49 ... No Checking if you have Text:
arseWords 0 ... Yes (3.27) Checking if you have File::Temp 0.15 ... Yes (0.22) Checking if you have File::Basename 0 ... Yes (2.77) Checking if you have Cwd 0 ... Yes (3.40) Checking if you have ExtUtils::Mkbootstrap 0 ... Yes (6.55_02) ==> Found dependencies: Test::More Searching Test::More on cpanmetadb ... --> Working on Test::More Fetching [www.cpan.org] -> OK Unpacking Test-Simple-0.98.tar.gz Entering Test-Simple-0.98 Checking configure dependencies from META.yml Checking if you have ExtUtils::MakeMaker 0 ... Yes (6.55_02) Configuring Test-Simple-0.98 Running Makefile.PL Checking if your kit is complete... Looks good Writing Makefile for Test:
imple -> OK Finding PREREQ from Makefile ... Checking if you have Test::Harness 2.03 ... Yes (3.17) Building and testing Test-Simple-0.98 cp lib/Test/Builder/Tester/Color.pm blib/lib/Test/Builder/Tester/Color.pm cp lib/Test/Builder.pm blib/lib/Test/Builder.pm cp lib/Test/Simple.pm blib/lib/Test/Simple.pm cp lib/Test/Builder/IO/Scalar.pm blib/lib/Test/Builder/IO/Scalar.pm cp lib/Test/More.pm blib/lib/Test/More.pm cp lib/Test/Builder/Tester.pm blib/lib/Test/Builder/Tester.pm cp lib/Test/Builder/Module.pm blib/lib/Test/Builder/Module.pm cp lib/Test/Tutorial.pod blib/lib/Test/Tutorial.pod Manifying blib/man3/Test::Builder::Tester::Color.3pm Manifying blib/man3/Test:
imple.3pm Manifying blib/man3/Test::Builder.3pm Manifying blib/man3/Test::Builder::IO:
calar.3pm Manifying blib/man3/Test::More.3pm Manifying blib/man3/Test::Builder::Module.3pm Manifying blib/man3/Test::Builder::Tester.3pm Manifying blib/man3/Test::Tutorial.3pm PERL_DL_NONLAZY=1 /usr/bin/perl "-MExtUtils::Command::MM" "-e" "test_harness(0, 'blib/lib', 'blib/arch')" t/*.t t/*/*.t t/00compile.t ........................... ok t/00test_harness_check.t ................ ok t/bad_plan.t ............................ ok t/bail_out.t ............................ ok t/BEGIN_require_ok.t .................... ok t/BEGIN_use_ok.t ........................ ok t/buffer.t .............................. ok t/Builder/carp.t ........................ ok t/Builder/create.t ...................... ok t/Builder/current_test.t ................ ok t/Builder/current_test_without_plan.t ... ok t/Builder/details.t ..................... ok t/Builder/done_testing.t ................ ok t/Builder/done_testing_double.t ......... ok t/Builder/done_testing_plan_mismatch.t .. ok t/Builder/done_testing_with_no_plan.t ... ok t/Builder/done_testing_with_number.t .... ok t/Builder/done_testing_with_plan.t ...... ok t/Builder/fork_with_new_stdout.t ........ ok t/Builder/has_plan.t .................... ok t/Builder/has_plan2.t ................... ok t/Builder/is_fh.t ....................... ok t/Builder/is_passing.t .................. ok t/Builder/maybe_regex.t ................. ok t/Builder/no_diag.t ..................... ok t/Builder/no_ending.t ................... ok t/Builder/no_header.t ................... ok t/Builder/no_plan_at_all.t .............. ok t/Builder/ok_obj.t ...................... ok t/Builder/output.t ...................... ok t/Builder/reset.t ....................... ok t/Builder/reset_outputs.t ............... ok t/Builder/try.t ......................... ok t/c_flag.t .............................. ok t/circular_data.t ....................... ok t/cmp_ok.t .............................. ok t/dependents.t .......................... skipped: Dependents only tested when releasing t/diag.t ................................ ok t/died.t ................................ ok t/dont_overwrite_die_handler.t .......... ok t/eq_set.t .............................. ok t/exit.t ................................ ok t/explain.t ............................. ok t/extra.t ............................... ok t/extra_one.t ........................... ok t/fail-like.t ........................... ok t/fail-more.t ........................... ok t/fail.t ................................ ok t/fail_one.t ............................ ok t/filehandles.t ......................... ok t/fork.t ................................ ok t/harness_active.t ...................... ok t/import.t .............................. ok t/is_deeply_dne_bug.t ................... ok t/is_deeply_fail.t ...................... ok t/is_deeply_with_threads.t .............. skipped: many perls have broken threads. Enable with AUTHOR_TESTING. t/missing.t ............................. ok t/More.t ................................ ok t/new_ok.t .............................. ok t/no_plan.t ............................. ok t/no_tests.t ............................ ok t/note.t ................................ ok t/overload.t ............................ ok t/overload_threads.t .................... ok t/plan.t ................................ ok t/plan_bad.t ............................ ok t/plan_is_noplan.t ...................... ok t/plan_no_plan.t ........................ ok t/plan_shouldnt_import.t ................ ok t/plan_skip_all.t ....................... skipped: Just testing plan & skip_all t/pod-coverage.t ........................ skipped: Test:
od::Coverage 1.08 required for testing POD coverage t/pod.t ................................. skipped: Test:
od 1.00 required for testing POD t/require_ok.t .......................... ok t/simple.t .............................. ok t/Simple/load.t ......................... ok t/skip.t ................................ ok t/skipall.t ............................. ok t/subtest/args.t ........................ ok t/subtest/basic.t ....................... ok t/subtest/die.t ......................... ok t/subtest/do.t .......................... ok t/subtest/exceptions.t .................. ok t/subtest/fork.t ........................ ok t/subtest/implicit_done.t ............... ok t/subtest/line_numbers.t ................ ok t/subtest/plan.t ........................ ok t/subtest/predicate.t ................... ok t/subtest/singleton.t ................... ok t/subtest/todo.t ........................ ok t/subtest/wstat.t ....................... ok t/tbm_doesnt_set_exported_to.t .......... ok t/Tester/tbt_01basic.t .................. ok t/Tester/tbt_02fhrestore.t .............. ok t/Tester/tbt_03die.t .................... ok t/Tester/tbt_04line_num.t ............... ok t/Tester/tbt_05faildiag.t ............... ok t/Tester/tbt_06errormess.t .............. ok t/Tester/tbt_07args.t ................... ok t/thread_taint.t ........................ ok t/threads.t ............................. ok t/todo.t ................................ ok t/undef.t ............................... ok t/use_ok.t .............................. ok t/useing.t .............................. ok t/utf8.t ................................ ok t/versions.t ............................ ok All tests successful. Files=107, Tests=1168, 3 wallclock secs ( 0.18 usr 0.21 sys + 1.24 cusr 0.72 csys = 2.35 CPU) Result: PASS Manifying blib/man3/Test::Builder::Tester::Color.3pm Manifying blib/man3/Test:
calar.3pm Manifying blib/man3/Test::More.3pm Manifying blib/man3/Test::Builder::Module.3pm Manifying blib/man3/Test::Builder::Tester.3pm Manifying blib/man3/Test::Tutorial.3pm Installing /usr/share/perl5/Test/Builder.pm Installing /usr/share/perl5/Test/More.pm Installing /usr/share/perl5/Test/Tutorial.pod Installing /usr/share/perl5/Test/Simple.pm Installing /usr/share/perl5/Test/Builder/Tester.pm Installing /usr/share/perl5/Test/Builder/Module.pm Installing /usr/share/perl5/Test/Builder/Tester/Color.pm Appending installation info to /usr/lib64/perl5/perllocal.pod -> OK Successfully installed Test-Simple-0.98 Building and testing Module-Build-0.4007 Building Module-Build t/00-compile.t ................. ok t/PL_files.t ................... ok t/actions/installdeps.t ........ ok t/actions/manifest_skip.t ...... ok t/add_property.t ............... ok t/add_property_array.t ......... ok t/add_property_hash.t .......... ok t/basic.t ...................... ok t/bundle_inc.t ................. skipped: $ENV{MB_TEST_EXPERIMENTAL} is not set t/compat.t ..................... ok t/compat/exit.t ................ ok t/debug.t ...................... ok t/destinations.t ............... ok t/ext.t ........................ ok t/extend.t ..................... ok t/files.t ...................... ok t/help.t ....................... ok t/install.t .................... ok t/install_extra_target.t ....... ok t/manifypods.t ................. ok t/manifypods_with_utf8.t ....... ok t/metadata.t ................... ok t/metadata2.t .................. ok t/mymeta.t ..................... ok t/new_from_context.t ........... ok t/notes.t ...................... ok t/par.t ........................ ok t/parents.t .................... ok t/perl_mb_opt.t ................ ok t/pod_parser.t ................. ok t/ppm.t ........................ ok t/properties/dist_suffix.t ..... ok t/properties/license.t ......... ok t/properties/module_name.t ..... ok t/properties/needs_compiler.t .. ok t/properties/release_status.t .. ok t/properties/requires.t ........ ok t/properties/share_dir.t ....... ok t/resume.t ..................... ok t/runthrough.t ................. ok t/sample.t ..................... ok t/script_dist.t ................ ok t/signature.t .................. ok t/test_file_exts.t ............. ok t/test_type.t .................. ok t/test_types.t ................. ok t/tilde.t ...................... ok t/unit_run_test_harness.t ...... ok t/use_tap_harness.t ............ ok t/versions.t ................... ok t/write_default_maniskip.t ..... ok t/xs.t ......................... ok All tests successful. Files=52, Tests=1132, 31 wallclock secs ( 0.13 usr 0.16 sys + 25.13 cusr 4.77 csys = 30.19 CPU) Result: PASS Building Module-Build Installing /usr/share/perl5/Module/Build.pm Installing /usr/share/perl5/Module/Build/YAML.pm Installing /usr/share/perl5/Module/Build/API.pod Installing /usr/share/perl5/Module/Build/Authoring.pod Installing /usr/share/perl5/Module/Build/Base.pm Installing /usr/share/perl5/Module/Build/Config.pm Installing /usr/share/perl5/Module/Build/Compat.pm Installing /usr/share/perl5/Module/Build/ConfigData.pm Installing /usr/share/perl5/Module/Build/Notes.pm Installing /usr/share/perl5/Module/Build/ModuleInfo.pm Installing /usr/share/perl5/Module/Build/PPMMaker.pm Installing /usr/share/perl5/Module/Build/Version.pm Installing /usr/share/perl5/Module/Build/PodParser.pm Installing /usr/share/perl5/Module/Build/Dumper.pm Installing /usr/share/perl5/Module/Build/Cookbook.pm Installing /usr/share/perl5/Module/Build/Platform/VOS.pm Installing /usr/share/perl5/Module/Build/Platform/darwin.pm Installing /usr/share/perl5/Module/Build/Platform/cygwin.pm Installing /usr/share/perl5/Module/Build/Platform/os2.pm Installing /usr/share/perl5/Module/Build/Platform/aix.pm Installing /usr/share/perl5/Module/Build/Platform/MacOS.pm Installing /usr/share/perl5/Module/Build/Platform/VMS.pm Installing /usr/share/perl5/Module/Build/Platform/Unix.pm Installing /usr/share/perl5/Module/Build/Platform/Windows.pm Installing /usr/share/perl5/Module/Build/Platform/Default.pm Installing /usr/bin/config_data -> OK Successfully installed Module-Build-0.4007 (upgraded from 0.35) Installing /usr/local/share/perl5/x86_64-linux-thread-multi/.meta/Module-Build-0.4007/install.json Installing /usr/local/share/perl5/x86_64-linux-thread-multi/.meta/Module-Build-0.4007/MYMETA.json Configuring Module-Build-WithXSpp-0.13 Running Build.PL Checking prerequisites... requires: ! ExtUtils::CppGuess is not installed ! ExtUtils:
arseXS (2.2203) is installed, but we need version >= 2.2205 ERRORS/WARNINGS FOUND IN PREREQUISITES. You may wish to install the versions of the modules indicated above before proceeding with this installation Created MYMETA.yml and MYMETA.json Creating new 'Build' script for 'Module-Build-WithXSpp' version '0.13' -> OK Checking dependencies from MYMETA.json ... Checking if you have Test::More 0 ... Yes (0.98) Checking if you have Digest::MD5 0 ... Yes (2.39) Checking if you have ExtUtils:
arseXS 2.2205 ... No (2.2203 < 2.2205) Checking if you have ExtUtils::Typemaps 1.00 ... Yes (3.18_04) Checking if you have ExtUtils:
Spp 0.11 ... Yes (0.1700) Checking if you have Module::Build 0.26 ... Yes (0.4007) Checking if you have ExtUtils::CppGuess 0.04 ... No Checking if you have ExtUtils::CBuilder 0 ... Yes (0.27) ==> Found dependencies: ExtUtils:
arseXS, ExtUtils::CppGuess Searching ExtUtils:
arseXS on cpanmetadb ... --> Working on ExtUtils:
arseXS Fetching [www.cpan.org] -> OK Unpacking ExtUtils-ParseXS-3.18.tar.gz Entering ExtUtils-ParseXS-3.18 Checking configure dependencies from META.json Checking if you have ExtUtils::MakeMaker 6.46 ... Yes (6.55_02) Configuring ExtUtils-ParseXS-3.18 Running Makefile.PL Checking if your kit is complete... Looks good Writing Makefile for ExtUtils:
arseXS -> OK Finding PREREQ from Makefile ... Checking if you have ExtUtils::MakeMaker 6.46 ... Yes (6.55_02) Checking if you have File:
pec 0 ... Yes (3.40) Checking if you have Symbol 0 ... Yes (1.07) Checking if you have Exporter 0 ... Yes (5.63) Checking if you have Carp 0 ... Yes (1.11) Checking if you have Test::More 0.47 ... Yes (0.98) Checking if you have File::Basename 0 ... Yes (2.77) Checking if you have DynaLoader 0 ... Yes (1.10) Checking if you have Cwd 0 ... Yes (3.40) Checking if you have ExtUtils::CBuilder 0 ... Yes (0.27) Building and testing ExtUtils-ParseXS-3.18 cp lib/ExtUtils/Typemaps/InputMap.pm blib/lib/ExtUtils/Typemaps/InputMap.pm cp lib/ExtUtils/ParseXS.pod blib/lib/ExtUtils/ParseXS.pod cp lib/ExtUtils/ParseXS/Utilities.pm blib/lib/ExtUtils/ParseXS/Utilities.pm cp lib/ExtUtils/Typemaps/Type.pm blib/lib/ExtUtils/Typemaps/Type.pm cp lib/ExtUtils/ParseXS/Constants.pm blib/lib/ExtUtils/ParseXS/Constants.pm cp lib/ExtUtils/ParseXS.pm blib/lib/ExtUtils/ParseXS.pm cp lib/ExtUtils/xsubpp blib/lib/ExtUtils/xsubpp cp lib/ExtUtils/Typemaps/OutputMap.pm blib/lib/ExtUtils/Typemaps/OutputMap.pm cp lib/ExtUtils/Typemaps/Cmd.pm blib/lib/ExtUtils/Typemaps/Cmd.pm cp lib/ExtUtils/ParseXS/CountLines.pm blib/lib/ExtUtils/ParseXS/CountLines.pm cp lib/ExtUtils/Typemaps.pm blib/lib/ExtUtils/Typemaps.pm cp lib/ExtUtils/xsubpp blib/script/xsubpp /usr/bin/perl -MExtUtils::MY -e 'MY->fixin(shift)' -- blib/script/xsubpp Manifying blib/man1/xsubpp.1 Manifying blib/man3/ExtUtils::Typemaps::InputMap.3pm Manifying blib/man3/ExtUtils:
arseXS.3pm Manifying blib/man3/ExtUtils:
arseXS::Utilities.3pm Manifying blib/man3/ExtUtils::Typemaps::Type.3pm Manifying blib/man3/ExtUtils:
arseXS::Constants.3pm Manifying blib/man3/ExtUtils::Typemaps::OutputMap.3pm Manifying blib/man3/ExtUtils::Typemaps::Cmd.3pm Manifying blib/man3/ExtUtils::Typemaps.3pm PERL_DL_NONLAZY=1 /usr/bin/perl "-MExtUtils::Command::MM" "-e" "test_harness(0, 'blib/lib', 'blib/arch')" t/*.t t/001-basic.t ............................ ok XSMore.c: In function ‘XS_XSMore_nil’: XSMore.c:493: warning: unused variable ‘items’ t/002-more.t ............................. ok XSUsage.c: In function ‘XS_XSUsage_two’: XSUsage.c:200: warning: unused variable ‘ix’ XSUsage.c: In function ‘XS_XSUsage_four’: XSUsage.c:236: warning: unused variable ‘items’ t/003-usage.t ............................ ok t/004-nolinenumbers.t .................... ok t/101-standard_typemap_locations.t ....... ok t/102-trim_whitespace.t .................. ok t/103-tidy_type.t ........................ ok t/104-map_type.t ......................... ok t/105-valid_proto_string.t ............... ok t/106-process_typemaps.t ................. ok t/107-make_targetable.t .................. ok t/108-map_type.t ......................... ok t/109-standard_XS_defs.t ................. ok t/110-assign_func_args.t ................. ok t/111-analyze_preprocessor_statements.t .. ok t/112-set_cond.t ......................... ok t/113-check_cond_preproc_statements.t .... ok t/114-blurt_death_Warn.t ................. ok t/115-avoid-noise.t ...................... ok t/501-t-compile.t ........................ ok t/510-t-bare.t ........................... ok t/511-t-whitespace.t ..................... ok t/512-t-file.t ........................... ok t/513-t-merge.t .......................... ok t/600-t-compat.t ......................... ok All tests successful. Files=25, Tests=213, 2 wallclock secs ( 0.04 usr 0.05 sys + 1.54 cusr 0.23 csys = 1.86 CPU) Result: PASS Manifying blib/man1/xsubpp.1 Manifying blib/man3/ExtUtils::Typemaps::InputMap.3pm Manifying blib/man3/ExtUtils:
arseXS::Constants.3pm Manifying blib/man3/ExtUtils::Typemaps::OutputMap.3pm Manifying blib/man3/ExtUtils::Typemaps::Cmd.3pm Manifying blib/man3/ExtUtils::Typemaps.3pm Installing /usr/share/perl5/ExtUtils/ParseXS.pod Installing /usr/share/perl5/ExtUtils/ParseXS.pm Installing /usr/share/perl5/ExtUtils/xsubpp Installing /usr/share/perl5/ExtUtils/Typemaps.pm Installing /usr/share/perl5/ExtUtils/Typemaps/Cmd.pm Installing /usr/share/perl5/ExtUtils/Typemaps/OutputMap.pm Installing /usr/share/perl5/ExtUtils/Typemaps/Type.pm Installing /usr/share/perl5/ExtUtils/Typemaps/InputMap.pm Installing /usr/share/perl5/ExtUtils/ParseXS/Constants.pm Installing /usr/share/perl5/ExtUtils/ParseXS/Utilities.pm Installing /usr/share/perl5/ExtUtils/ParseXS/CountLines.pm Installing /usr/share/man/man1/xsubpp.1 Installing /usr/share/man/man3/ExtUtils::Typemaps::OutputMap.3pm Installing /usr/share/man/man3/ExtUtils:
arseXS::Utilities.3pm Installing /usr/share/man/man3/ExtUtils::Typemaps::InputMap.3pm Installing /usr/share/man/man3/ExtUtils::Typemaps::Cmd.3pm Installing /usr/share/man/man3/ExtUtils::Typemaps::Type.3pm Installing /usr/share/man/man3/ExtUtils:
arseXS::Constants.3pm Installing /usr/share/man/man3/ExtUtils:
arseXS.3pm Installing /usr/share/man/man3/ExtUtils::Typemaps.3pm Installing /usr/bin/xsubpp Appending installation info to /usr/lib64/perl5/perllocal.pod -> OK Successfully installed ExtUtils-ParseXS-3.18 (upgraded from 2.2203) Searching ExtUtils::CppGuess on cpanmetadb ... --> Working on ExtUtils::CppGuess Fetching [www.cpan.org] -> OK Unpacking ExtUtils-CppGuess-0.07.tar.gz Entering ExtUtils-CppGuess-0.07 Checking configure dependencies from META.yml Checking if you have Module::Build 0.36 ... Yes (0.4007) Checking if you have Module::Build 0.36 ... Yes (0.4007) Configuring ExtUtils-CppGuess-0.07 Running Build.PL Created MYMETA.yml and MYMETA.json Creating new 'Build' script for 'ExtUtils-CppGuess' version '0.07' -> OK Checking dependencies from MYMETA.json ... Checking if you have Capture::Tiny 0 ... Yes (0.22) Checking if you have Fatal 0 ... Yes (2.06_01) Checking if you have ExtUtils::MakeMaker 0 ... Yes (6.55_02) Checking if you have File:
pec 0 ... Yes (3.40) Checking if you have Test::More 0 ... Yes (0.98) Checking if you have File::Basename 0 ... Yes (2.77) Checking if you have Module::Build 0 ... Yes (0.4007) Checking if you have ExtUtils::Manifest 0 ... Yes (1.56) Checking if you have Cwd 0 ... Yes (3.40) Building and testing ExtUtils-CppGuess-0.07 uilding ExtUtils-CppGuess t/001_load.t .......... ok # Failed test 'build with Module::Build' # at t/010_module_build.t line 12. # Build.PL output # ======================================== # Created MYMETA.yml and MYMETA.json # Creating new 'Build' script for 'CppGuessTest' version '0.01' # ======================================== # Build output # ======================================== # Building CppGuessTest # gcc -I/usr/lib64/perl5/CORE -DXS_VERSION="0.01" -DVERSION="0.01" -fPIC -xc++ -D_FILE_OFFSET_BITS=64 -c -D_REENTRANT -D_GNU_SOURCE -fno-strict-aliasing -pipe -fstack-protector -I/u sr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic - o lib/CppGuessTest.o lib/CppGuessTest.c # gcc: error trying to exec 'cc1plus': execvp: No such file or directory # error building lib/CppGuessTest.o from 'lib/CppGuessTest.c' at /usr/share/perl5/ExtUtils/CBuilder/Base.pm line 112. # ======================================== # Looks like you failed 1 test of 1. t/010_module_build.t .. Dubious, test returned 1 (wstat 256, 0x100) Failed 1/1 subtests # Failed test 'build with ExtUtils::MakeMaker' # at t/011_makemaker.t line 12. # Makefile.PL output # ======================================== # Checking if your kit is complete... # Looks good # Writing Makefile for CppGuessTest # ======================================== # make output # ======================================== # cp lib/CppGuessTest.pm blib/lib/CppGuessTest.pm # /usr/bin/perl /usr/share/perl5/ExtUtils/xsubpp -typemap /usr/share/perl5/ExtUtils/typemap -typemap typemap CppGuessTest.xs > CppGuessTest.xsc && mv CppGuessTest.xsc CppGuessTest .c # gcc -c -xc++ -D_FILE_OFFSET_BITS=64 -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic -DVERSION=\"0.01\" -DXS_VERSION=\"0.01\" -fPIC "-I/usr/lib64/perl5/CORE" CppGuessTest.c # gcc: error trying to exec 'cc1plus': execvp: No such file or directory # make: *** [CppGuessTest.o] Error 1 # ======================================== # Looks like you failed 1 test of 1. t/011_makemaker.t ..... Dubious, test returned 1 (wstat 256, 0x100) Failed 1/1 subtests Test Summary Report ------------------- t/010_module_build.t (Wstat: 256 Tests: 1 Failed: 1) Failed test: 1 Non-zero exit status: 1 t/011_makemaker.t (Wstat: 256 Tests: 1 Failed: 1) Failed test: 1 Non-zero exit status: 1 Files=3, Tests=3, 1 wallclock secs ( 0.01 usr 0.01 sys + 0.60 cusr 0.11 csys = 0.73 CPU) Result: FAIL Failed 2/3 test programs. 2/3 subtests failed. -> FAIL Installing ExtUtils::CppGuess failed. See /root/.cpanm/work/1375866935.2077/build.log for details. Retry with --force to force install it. -> FAIL Installing the dependencies failed: Module 'ExtUtils::CppGuess' is not installed -> FAIL Bailing out the installation for Module-Build-WithXSpp-0.13. Already tried ExtUtils::CppGuess. Skipping. Already tried ExtUtils::CppGuess. Skipping. Already tried Module::Build. Skipping. -> FAIL Installing the dependencies failed: Module 'Module::Build::WithXSpp' is not installed, Module 'ExtUtils::CppGuess' is not installed -> FAIL Bailing out the installation for Boost-Geometry-Utils-0.15. 3 distributions installed
Re: Problems running slic3r on CentOS 6.4 x64 August 07, 2013 08:11AM |
[root@centos64 Slic3r]# perl Build.PL App::cpanminus is up to date. (1.6939) Boost::Geometry::Utils is up to date. (0.15) Class:SAccessor is up to date. (1.18) Encode::Locale is up to date. (1.03) skipping R/RJ/RJBS/perl-5.18.0.tar.bz2 File:
calar is up to date. (2.110) Math::Clipper is up to date. (1.22) Math::ConvexHull::MonotoneChain is up to date. (0.01) Math::Geometry::Voronoi is up to date. (1.3) Math:
AX::ExpatXS is up to date. (1.33) --> Working on SMUELLER/ExtUtils-ParseXS-3.18_04.tar.gz Fetching [www.cpan.org] ... OK Configuring ExtUtils-ParseXS-3.18_04 ... OK Building and testing ExtUtils-ParseXS-3.18_04 ... OK Successfully installed ExtUtils-ParseXS-3.18_04 1 distribution installed --> Working on ./xs Configuring /root/Slic3r/xs ... OK Building and testing Slic3r-XS-0.01 ... OK Successfully installed Slic3r-XS-0.01 1 distribution installed t/angles.t ........... ok t/arcs.t ............. ok t/clean_polylines.t .. ok t/clipper.t .......... ok t/collinear.t ........ ok t/combineinfill.t .... ok t/cooling.t .......... ok t/custom_gcode.t ..... ok t/dynamic.t .......... skipped: variable-width paths are currently disabled t/fill.t ............. ok t/gcode.t ............ ok t/geometry.t ......... ok t/layers.t ........... ok t/loops.t ............ ok t/perimeters.t ....... ok t/polyclip.t ......... ok t/print.t ............ ok t/retraction.t ....... ok t/serialize.t ........ ok t/shells.t ........... ok t/skirt_brim.t ....... ok t/slice.t ............ ok t/support.t .......... 1/13 Argument "100%" isn't numeric in numeric lt (<) at /root/Slic3r/t/../lib/Slic3r/Print/Object.pm line 913. # Looks like you planned 13 tests but ran 12. # Looks like your test exited with 255 just after 12. t/support.t .......... Dubious, test returned 255 (wstat 65280, 0xff00) Failed 1/13 subtests t/svg.t .............. ok t/vibrationlimit.t ... ok Test Summary Report ------------------- t/support.t (Wstat: 65280 Tests: 12 Failed: 0) Non-zero exit status: 255 Parse errors: Bad plan. You planned 13 tests but ran 12. Files=25, Tests=238, 40 wallclock secs ( 0.04 usr 0.09 sys + 39.29 cusr 0.38 csys = 39.80 CPU) Result: FAIL [root@centos64 Slic3r]#
Re: Problems running slic3r on CentOS 6.4 x64 August 07, 2013 11:52AM |
