Cannot use --gui build switch on linux August 11, 2013 06:08PM |
cpanm (App::cpanminus) 1.6940 on perl 5.014002 built for x86_64-linux-gnu-thread-multi Work directory is /home/spaceman/.cpanm/work/1376254786.8729 You have make /usr/bin/make You have LWP 6.03 You have /bin/tar: tar (GNU tar) 1.26 Copyright (C) 2011 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later [gnu.org]. This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. Written by John Gilmore and Jay Fenlason. You have /usr/bin/unzip Searching Wx::GLCanvas on cpanmetadb ... --> Working on Wx::GLCanvas Fetching [www.cpan.org] -> OK Unpacking Wx-GLCanvas-0.09.tar.gz Entering Wx-GLCanvas-0.09 Checking configure dependencies from META.yml Checking if you have Wx::build::MakeMaker 0.16 ... Yes (0.28) Configuring Wx-GLCanvas-0.09 Running Makefile.PL Checking if your kit is complete... Looks good 'WX' is not a known MakeMaker parameter name. Unrecognized argument in LIBS ignored: '-Wl,-Bsymbolic-functions' Unrecognized argument in LIBS ignored: '-Wl,-z,relro' Writing Makefile for Wx::GLCanvas Writing MYMETA.yml and MYMETA.json -> OK Checking dependencies from MYMETA.json ... Checking if you have Wx 0.57 ... Yes (0.9922) Checking if you have ExtUtils::MakeMaker 0 ... Yes (6.72) Checking if you have Wx::build::MakeMaker 0.16 ... Yes (0.28) Building and testing Wx-GLCanvas-0.09 cp lib/Wx/GLCanvas.pm blib/lib/Wx/GLCanvas.pm cp lib/Wx/DemoModules/wxGLCanvas.pm blib/lib/Wx/DemoModules/wxGLCanvas.pm /usr/bin/perl -S wxperl_overload cpp/ovl_const.cpp cpp/ovl_const.h overload.lst Writing 'cpp/ovl_const.h'. Writing 'cpp/ovl_const.cpp'. touch wxt_overload /usr/bin/perl /usr/local/share/perl/5.14.2/ExtUtils/xsubpp -noprototypes -typemap /usr/share/perl/5.14/ExtUtils/typemap -typemap /usr/local/lib/perl/5.14.2/Wx/typemap -typemap typemap GLCanvas.xs > GLCanvas.xsc && mv GLCanvas.xsc GLCanvas.c g++ -pthread -c -I. -I/usr/local/lib/perl/5.14.2/Wx -I/usr/lib/x86_64-linux-gnu/wx/include/gtk2-unicode-release-2.8 -I/usr/include/wx-2.8 -D_REENTRANT -D_GNU_SOURCE -DDEBIAN -fno-strict-aliasing -pipe -fstack-protector -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -O2 -g -DVERSION=\"0.09\" -DXS_VERSION=\"0.09\" -fPIC "-I/usr/lib/perl/5.14/CORE" -DWXPL_EXT -D_FILE_OFFSET_BITS=64 -D_LARGE_FILES -D__WXGTK__ GLCanvas.c In file included from /usr/include/wx-2.8/wx/glcanvas.h:54:0, from GLCanvas.xs:27: /usr/include/wx-2.8/wx/gtk/glcanvas.h:19:19: fatal error: GL/gl.h: No such file or directory compilation terminated. make: *** [GLCanvas.o] Error 1 -> FAIL Installing Wx::GLCanvas failed. See /home/spaceman/.cpanm/work/1376254786.8729/build.log for details. Retry with --force to force install it.
Re: Cannot use --gui build switch on linux August 11, 2013 09:25PM |
Re: Cannot use --gui build switch on linux August 12, 2013 10:24PM |
cpanm (App::cpanminus) 1.6940 on perl 5.014002 built for x86_64-linux-gnu-thread-multi Work directory is /home/spaceman/.cpanm/work/1376359623.6762 You have make /usr/bin/make You have LWP 6.03 You have /bin/tar: tar (GNU tar) 1.26 Copyright (C) 2011 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later [gnu.org]. This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. Written by John Gilmore and Jay Fenlason. You have /usr/bin/unzip --> Working on [www.cpan.org] Fetching [www.cpan.org] -> OK Unpacking OpenGL-0.67.tar.gz Entering OpenGL-0.67 Checking configure dependencies from META.json Checking if you have ExtUtils::MakeMaker 0 ... Yes (6.72) Configuring OpenGL-0.67 Running Makefile.PL /usr/bin/ld: cannot find -lXmu collect2: ld returned 1 exit status make: *** [glversion] Error 1 -> N/A Checking dependencies from MYMETA.json ... Checking if you have Test::More 0 ... Yes (0.98) Checking if you have ExtUtils::MakeMaker 0 ... Yes (6.72) -> FAIL Configure failed for OpenGL-0.67. See /home/spaceman/.cpanm/work/1376359623.6762/build.log for details.
