Has anyone tried to slice an object with the following settings:
; generated by Slic3r 0.9.10b on 2013-10-01 at 07:24:13
; layer_height = 0.5
; perimeters = 3
; top_solid_layers = 3
; bottom_solid_layers = 3
; fill_density = .4
; perimeter_speed = 30
; infill_speed = 60
; travel_speed = 60
; nozzle_diameter = 0.5
; filament_diameter = 1.75
; extrusion_multiplier = .80
; perimeters extrusion width = 0.53mm
; infill extrusion width = 0.53mm
; solid infill extrusion width = 0.53mm
; top infill extrusion width = 0.53mm
; first layer extrusion width = 1.00mm
What I am getting when I look at the generated gcode is a missing layer. It is leaving a gap between each layer.
This is everything from .5 to .95
Same problem with .5mm tip with a .4 Layer Height
; generated by Slic3r 0.9.10b on 2013-10-01 at 09:35:47
; layer_height = 0.4
; perimeters = 3
; fill_density = .4
; infill_speed = 60
; travel_speed = 60
; first layer extrusion width = 0.80mm
Thanks
Edited 3 time(s). Last edit at 10/01/2013 11:41AM by Adventure.
Jeff Christiana
