Slic3r profiles (moving computers)
Posted by BJacoby
October 21, 2013 10:42AM
Where are the profiles stored?
Trying to export the multiple profiles I have on one computer to a newer laptop (both Windows). The manual seems to show only exporting the current profile combination.
Is this just a matter of zipping up the slic3r subdirectory and moving it?
Thanks in advance for the help.
Re: Slic3r profiles (moving computers)
October 21, 2013 10:57AM
I'm not on a system where I can check right now, but it's somewhere inside the AppData folder, which is a hidden directory in your home folder. And yes - these are simple text files and it is an easy matter to just copy them to the new system
October 21, 2013 07:05PM
Yes you can just copy the Slic3r directory (compress it if you like, but the files are small enough it wouldn't matter in most cases).
As mentioned, for Vista/7/8 it's:
C:\Users\\AppData\Roaming\Slic3r
If you use Slic3r through Repetier Host, you may also find some stuff under AppData\Local\RepetierHost
October 21, 2013 08:39PM
Evil hidden files! FYI for others:
The "from" machine is XP and the profiles are stored in C:\Documents and Settings\(user)\Application Data\Slic3r
