Why can't I slice something I made in Sketchup? November 17, 2013 03:47PM |
Re: Why can't I slice something I made in Sketchup? November 17, 2013 03:53PM |
Re: Why can't I slice something I made in Sketchup? November 17, 2013 07:19PM |
Re: Why can't I slice something I made in Sketchup? November 17, 2013 07:43PM |
Re: Why can't I slice something I made in Sketchup? November 17, 2013 07:49PM |
Re: Why can't I slice something I made in Sketchup? November 17, 2013 08:05PM |
Re: Why can't I slice something I made in Sketchup? November 17, 2013 08:52PM |
uncle_bob
An easier way to do this:
1) Just make a cube the right outer size. Nothing fancy, just a cube.
2) Tell Silc3r to do zero top layers - now it's an open cube
3) Tell Slic3r you want zero fill - now it's a box
4) Tell Siic3r you want 10 perimeter layers. With a .4 mm head you now have a very solid 4 mm wall.
Takes very little time that way. You can even print it up as a Spiral Vase if you want to .
Re: Why can't I slice something I made in Sketchup? November 17, 2013 11:23PM |
Re: Why can't I slice something I made in Sketchup? November 18, 2013 04:49PM |
uncle_bob
Re: Why can't I slice something I made in Sketchup? November 18, 2013 04:52PM |
vetteguy112233
tmorris9
I tried fixing your file but it was very messed up. Not sure how or what happened but I just whipped up the same object for you that works (took 10 minutes).
What program did you use? Did you go about it the same way that I just described?
Re: Why can't I slice something I made in Sketchup? November 18, 2013 10:15PM |
Re: Why can't I slice something I made in Sketchup? November 18, 2013 10:21PM |
Re: Why can't I slice something I made in Sketchup? November 18, 2013 10:42PM |
Re: Why can't I slice something I made in Sketchup? November 19, 2013 10:23PM |
vetteguy112233
I still would like to know why the other method didn't work.
Re: Why can't I slice something I made in Sketchup? November 20, 2013 03:20AM |
vetteguy112233
Re: Why can't I slice something I made in Sketchup? November 20, 2013 02:02PM |
Re: Why can't I slice something I made in Sketchup? November 20, 2013 08:44PM |
Re: Why can't I slice something I made in Sketchup? January 23, 2015 10:25AM |
Re: Why can't I slice something I made in Sketchup? January 23, 2015 08:48PM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Why can't I slice something I made in Sketchup? January 23, 2015 10:59PM |
