Custom G-code after extruder hit temperature possible?
Posted by Azrael_UK
November 25, 2013 01:57PM
I'm running Slicer 1.0.0RC, I was wondering if there's any way have a short section of custom G-code such that it's run after the extruder has reached target temperature? I tried putting it into the start G-code box but that seems to run after the bed has hit temp but before the extruder is brought up to temperature.
Prussa i2 Comissioned 4-Nov-2013
Bitcoin : 1Jcrg5czBtNfKyS4sCjFAamJTcSYdTGk9h
Re: Custom G-code after extruder hit temperature possible?
November 26, 2013 11:57AM
OK, I figured out how to do that...
Insert a
M109 S[first_layer_temperature]
into the startup G-code box and what I want to happen after heat is reached after that
Now for the next question..........
Is there any way to combine the
G1 Z0.300 F9000.000
G1 X85.050 Y85.230 F9000.000
that Slic3r starts with on first layer into a single command, so it moves all 3 axis at once?
November 26, 2013 12:02PM
Edit the gcode file and combine the two lines, Slic3r does not do this.:
G1 X85.050 Y85.230 Z0.300 F9000.000
November 26, 2013 12:09PM
OK thanks, I was hoping there was some setting that would do this automatically but if editing the G-code is the only way I guess that's the answer sad smiley
Edit : A thought... Could a suitable routine entered in the "post processing script" be used to combine those two lines after Slic3r has done it's work?
Edited 1 time(s). Last edit at 11/26/2013 12:17PM by Azrael_UK.
November 26, 2013 12:18PM
You could always add the above codeline into customs start code as a virtual start point.
November 26, 2013 12:33PM
Thanks for the suggestion, I'll look into that, do a few tests, see if it can get the head moving the way I want to smiling smiley
