Re: Help, internal size of part(s) too small... January 03, 2014 10:53AM |
Re: Help, internal size of part(s) too small... January 04, 2014 04:25AM |
Re: Help, internal size of part(s) too small... January 05, 2014 01:51PM |
Re: Help, internal size of part(s) too small... January 05, 2014 02:30PM |
Re: Help, internal size of part(s) too small... January 05, 2014 03:39PM |
Re: Help, internal size of part(s) too small... January 05, 2014 04:03PM |
Re: Help, internal size of part(s) too small... January 05, 2014 04:15PM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: Help, internal size of part(s) too small... January 05, 2014 10:03PM |
Re: Help, internal size of part(s) too small... January 06, 2014 06:02AM |
Re: Help, internal size of part(s) too small... January 06, 2014 08:47AM |
Re: Help, internal size of part(s) too small... January 06, 2014 02:22PM |
Re: Help, internal size of part(s) too small... January 06, 2014 03:03PM |
Re: Help, internal size of part(s) too small... January 06, 2014 06:21PM |
Re: Help, internal size of part(s) too small... January 06, 2014 08:05PM |
Sound
We could probably do something right now, while we figure out the bigger picture.
- An inset value (in mm) to apply to the outer loop (in addition to extrusion_width/2 which is already applied)
- An additional extrusion multiplier to apply to the outer loop (to allow user to reduce flow as Sublime proposes)
Re: Help, internal size of part(s) too small... January 25, 2014 08:01PM |
Re: Help, internal size of part(s) too small... January 26, 2014 04:32AM |
Re: Help, internal size of part(s) too small... March 14, 2014 06:29AM |
nophead
I think your assessment is fair. Neither Sound or Daid recognize the problem, so I doubt they would even accept patches to fix it.
Re: Help, internal size of part(s) too small... March 17, 2014 04:19AM |
Re: Help, internal size of part(s) too small... April 02, 2014 07:05PM |
Re: Help, internal size of part(s) too small... April 05, 2014 09:34AM |
Re: Help, internal size of part(s) too small... May 27, 2014 12:58PM |
Re: Help, internal size of part(s) too small... May 27, 2014 02:15PM |
to-the-nth
@Sublime - Looks like Sound has not added an inset feature to the new 1.1.3 release which is fine. But to continue algorithm development, what would it take to try to get your Flow_tweak-post-processor script running on Slic3r?
| FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
| Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Help, internal size of part(s) too small... May 27, 2014 05:36PM |
@nophead - do you agree that Sound and Daid recognize the problem, but that there is just no clear easy fix-all algorithm that can be implemented?
Re: Help, internal size of part(s) too small... May 28, 2014 03:25AM |
Re: Help, internal size of part(s) too small... May 28, 2014 03:44AM |
Re: Help, internal size of part(s) too small... May 28, 2014 11:50AM |
to-the-nth
@Sublime - I was hoping you could sprinkle some magic dust on this since you did the flow rate script for non-Slic3r. I assume the script keys off of the comments and we would like to target a flow rate adjustment on the outer perimeter. Does Cura distinguish between inner, middle and outer most perimeters? Slic3r comments don't distinguish between inner, middle, and outer. Did you have to mine data to know when an outer most perimeter on a layer started? or did you just tweak the flow rate on all perimeters; inner, middle and outer?
Re: Help, internal size of part(s) too small... May 30, 2014 02:56AM |
Re: Help, internal size of part(s) too small... May 30, 2014 11:06PM |
to-the-nth
@Sublime - Looking at some Slic3r Gcode comments; there is a "move to first perimeter point" followed by a series a "perimeter" command comments. No indication of which perimeters are the outer most.
Could set an unique external perimeter speed for the script to key off of. Problem is the small perimeters speed over rides the external perimeters speed.
For a Slic3r post script, only simple option I see it to adjust the flow rates of all perimeters, and tweak the flow rate equation math. Not optimum.
Re: Help, internal size of part(s) too small... June 01, 2014 12:50PM |
Re: Help, internal size of part(s) too small... June 09, 2014 02:27AM |
