Changing Layer Heights Affects Extrusion Widths December 05, 2013 04:26PM |
Re: Changing Layer Heights Affects Extrusion Widths December 05, 2013 05:56PM |
Re: Changing Layer Heights Affects Extrusion Widths December 05, 2013 06:01PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Changing Layer Heights Affects Extrusion Widths December 05, 2013 06:18PM |
Re: Changing Layer Heights Affects Extrusion Widths December 05, 2013 06:22PM |
Re: Changing Layer Heights Affects Extrusion Widths December 05, 2013 09:05PM |
Re: Changing Layer Heights Affects Extrusion Widths December 05, 2013 10:02PM |
Re: Changing Layer Heights Affects Extrusion Widths December 05, 2013 10:23PM |
Erik G
Hey Sublime,
Question for you really quick.
Im tryin out KISS and i was wondering what your setting for skin thickness is set to.
Default is .8 and extrusion width is .5
I am changing the e width to .53 as per your calc. good work. Bookmarked indeed.
I am going to experiment with a thin wall test and measure it and see what happens,
I am assuming a single wall will be the extrusion width, and anything with infill will have the skin thickness.
your thoughts?
-E
Re: Changing Layer Heights Affects Extrusion Widths December 05, 2013 10:56PM |
Re: Changing Layer Heights Affects Extrusion Widths December 05, 2013 11:31PM |
Sublime
Also when I say the extrusion is too wide is not a bug where Slic3r puts out too much plastic for the width it has decided to use....
Re: Changing Layer Heights Affects Extrusion Widths December 05, 2013 11:56PM |
Erik G
Sublime
That makes sense. I guess i hadnt thought if it in quite those terms. I am going to use the clay example when explaining this to others.
As far as the skin thickness goes: if i do a singe wall thickness part, should this be set to my extruder width?
(edit you mentioned 2 perimeters, set your skin to .9 or 1, your talking about the number of loops setting correct?
for three perimeters i would set skin to 1.4-1.5, if i am under standing this correctly?
Erik G
New development:
When i slice this part in KISS, i get gaps between the print. Ill attach my gcode so you can have a look at what the output of KISS was. Its just a thin wall test... really odd.It happens with other single wall models from thingiverse too. so its not just my model.
Erik G
If there is a way to export my KISS settings so you can have a look at them, i will do so.
Re: Changing Layer Heights Affects Extrusion Widths December 06, 2013 12:21PM |
Re: Changing Layer Heights Affects Extrusion Widths December 06, 2013 12:31PM |
justcurious
Before you make too hasty decisions on which Slicer to use and which not, there is a lot of information out there you may consider. You are making a lot of noise on not quite simple problems which may influence a lot of good peoples effort to give you (for free) some advanced programs you are not able to make yourself. And that is a pity :-(.
Some of you may have seen this before and for others it could inspire to some rethinking of the problems you meet.
Take a look on this written by a person that has made a lot of good thinking related to these not simple problems:
http://hydraraptor.blogspot.dk/2011/02/polyholes.html
Think about it and also which other parameters that may have influence on endresult, like calibration, viscosity of material, temperature, extruder, use of fan , bad habits etc...
and when you have come to some conclusions you may contribute to the developers of some really good ideas on how to make these programs even better by suggestions on how to do that.
Nophead
I use my own maths with SF because you input the flow rate versus feed rate and I don't set them the same for the outline.
Re: Changing Layer Heights Affects Extrusion Widths December 06, 2013 01:00PM |
Re: Changing Layer Heights Affects Extrusion Widths December 06, 2013 01:03PM |
Re: Changing Layer Heights Affects Extrusion Widths December 06, 2013 01:49PM |
justcurious
re Sublime
Nophead writes this as a start to his guidance, which is the reason he has worked on what to do about it.:
"When Reprap machines print holes they tend to come out undersized, even if the linear dimensions of an object are spot on.
There are several effects that all make holes smaller than they should be: -"
I have deep respect for the work you have made to better understand how extruders are working, but I am not sure that it is the best way to guide the majority of users to get the best results, but that is just my opinion, so you should of course keep up the good work.
I have no knowledge on how much of this information is included into different slicers or just ignored, but that could be a start to get verified. Nophead suggest in his article on how to compensate in the cad program, that is another way of doing it. i would be happy if all of my programs could take care of these problems, but they obviously don't and you suggestions are a way of getting around. They did not solve all my problems, but certainly showed a way of getting better and developers may learn a few things here (i)
I do not have very lonng experience on this playground, but I try to have an open mind for progress. Sofar some of my problems are with circles that seems to be under meaure but that goes for inner and outer circles just like Nophead is suggesting and I need a lot of more testing to conclude anything valid yet.
Re: Changing Layer Heights Affects Extrusion Widths December 06, 2013 01:54PM |
Erik G
what is your tool chain?
-E
Re: Changing Layer Heights Affects Extrusion Widths December 06, 2013 03:19PM |
Re: Changing Layer Heights Affects Extrusion Widths December 06, 2013 04:13PM |
lua "Flow_rate.lua" " < FILE > " without the spaces around the word FILE (the forum removes the < FILE and > if the spaces are not thereto the post-process field in the firmware tab of Kisslicer. Then at the top of the script file you will see where the variables are set to adjust the flow rate of each extrusion type, default 100%.
Re: Changing Layer Heights Affects Extrusion Widths December 06, 2013 08:02PM |
Re: Changing Layer Heights Affects Extrusion Widths December 06, 2013 08:47PM |
Erik G
Very cool. Ill have a look through that, once i get through the back log of other things i need to do.
I noticed that KISS comments what is going on in the Gcode, which i assume is how you are able to parse the gcode to change flow rates.
How would this be done in something like slic3r? Looking at dimensions? hmm.. ill have to ponder that for a while.
Ill give your script a try at some point and if i like the results from KISS i may try to get it to work with slic3r.
unless i end up liking KISS better which may just happen.
Cheers, Happy friday all.
-Erik
Re: Changing Layer Heights Affects Extrusion Widths December 06, 2013 11:08PM |
Re: Changing Layer Heights Affects Extrusion Widths December 07, 2013 03:41AM |
Re: Changing Layer Heights Affects Extrusion Widths December 07, 2013 05:46AM |
I am impressed of your creativity to find new ways, and I hope I find some time to follow your inspiring effort and maybe this could be a way of making influence to developers with this :-).Quote
Sublime
I created a github repo for it and added parsing for Cura gcode as well. [github.com]
Sic3r parsing will be harder since it adds the comments to the end of every single line of code.
Re: Changing Layer Heights Affects Extrusion Widths December 07, 2013 11:38AM |
justcurious
Sublime
i had never heard of LURA but why not?
Slic3r has already (1.0) possibily of dedicated flow settings for different extrusion types and together with speed settings for this, would that not give you the same opportunities as your script?
Re: Changing Layer Heights Affects Extrusion Widths December 07, 2013 12:28PM |
Sublime
I just went through all the setting in Slic3r rc1 in expert mode and it only allows you to adjust the flow for bridges and for the entire print. I could not find anywhere it let you adjust the flow independently for each path type. You can adjust the extrusion size but that effects the size of the extrusion as well as where it is placed. With this script it actually allows you to slightly under extrude. It does this because the outer extruded path is not a square extrusion equal to the height and width but rather it has a rounded outer edge that will protrude past the edge. So Nophead wrote an equation that calculates the difference between the volume of a square extrusion and a rounded extrusion on the outside and reduces the flow to create a rounded extrusion that lines up with the edge calculated for a square extrusion. This is how Nophead prints with Skeinforge which is the only software he gets accurate results with.
Re: Changing Layer Heights Affects Extrusion Widths December 07, 2013 03:19PM |
justcurious
Sublime
I am not sure I understand your explanation of difference between change of Extrusion Width vs flow. Any extrusion has a profile of a rounded rectangle which does not change with extrusion width and the change of flow with change of extrusion width is a rectangle sized of layerheightXchange of extrusion width as long as speed is not changed. I thought that the whole idea of changing extrusion width was to change the path slightly to enter a zone more compatible to the original cad file? iDo you think that slicers have an error because they calculate flow with rectangles only?
Re: Changing Layer Heights Affects Extrusion Widths December 07, 2013 04:23PM |
Re: Changing Layer Heights Affects Extrusion Widths December 07, 2013 05:26PM |
justcurious
huh...it sure is complicated stuff and I am afraid there is not one single answer.
You have proved that your method is working, that is for sure, but I am also quite sute that somehow you have used every inch of knowledge from your machine and experience with materials to get there and most of us may never get that far :-(.
I jumped into this discussion because I am also tired of all the complaints about these issues without finding good answers. It is a problem that far too many parameters change when people are tweaking these things, so probably you will never find two conditions being the same and that makes it hard to discuss .
I also feel that developers get frustrated because most of these complaints never gets fully documented to be registered as an actually bug, so it is very hard to actually do something about it as a sw problem.
Nevertheless i think it is vital to keep uncovering the actual problem to get to an understanding on how to change things if possible, and your effort thas been amazing with the experience and insight you have obtained. it would be fine if some people involved in the slicing sw industry would enter the arena and enlight some of the mistakes expressed or alternatively could we as users try harder to make some descriptions of what we see as not too perfect sw and togethe we might find a way where complaints could be a rare case instead.
Re: Changing Layer Heights Affects Extrusion Widths December 08, 2013 01:26PM |
