Please help a newbie out!
Posted by Matmo
December 23, 2013 12:14AM
Hey guys,
So I’m totally new to 3d printing, as well as programming in general (I’m only 16 and have been busy with school). I have a Vision 3d Printer(http://www.kickstarter.com/projects/vision3dprinter/the-vision-not-just-a-3d-printer-a-dream) , and I have already built my printer. As you can see, it is very similar to traditional RepRap printers. I don’t know how to perform a systems check to be sure the printer is assembled correctly, so would appreciate any help with this aspect. Regarding the software, I downloaded Slic3r and Printrun, and have them installed on my MacBook Pro(running 10.6.8), and the programs open but I do not know what to do from this point on.
Can anyone walk me through simplified instructions to change the settings of Slic3r and Printrun so that they work with the Vision printer? If you have any links to a website that shows me how to do this, that would also be appreciated.
Thanks,
Matt
Re: Please help a newbie out!
December 23, 2013 05:43PM
I am not a software guy. I would think they would have given you instructions to at least get you printing. You first need to get the printer to communicate with the program, this involves setting up speed (baud rate) and such like with the old modems (again I am not a software guy) If they did not give you any settings you could try here [www.reprap.org] as they use the Marlin firmware.
I would make one suggestion, dump Printrun and download Repetier Host instead ( [www.repetier.com] ). It will doe everything Printrun does and more, it's easier to use, has a much better interface and gives you much better visual feedback (and yes, it's Mac compatible) and it will work with any printer that Printrun will.
Once you get them talking you can use the manual controls of either program to test the movement (X,Y & Z) to see if everything is working. Then load up a simple gcode and see if it prints. You may need to do calibration but again I am not a software guy so that's beyond me.
Good luck.
