Honeycomb infill: first layer displacement December 24, 2013 01:39PM |
Re: Honeycomb infill: first layer displacement December 24, 2013 03:41PM |
Re: Honeycomb infill: first layer displacement December 24, 2013 04:23PM |
Re: Honeycomb infill: first layer displacement December 24, 2013 04:49PM |
Re: Honeycomb infill: first layer displacement December 24, 2013 11:23PM |
Re: Honeycomb infill: first layer displacement December 24, 2013 11:27PM |
Re: Honeycomb infill: first layer displacement December 25, 2013 01:52AM |
tmorris9
Is your object straight? (like a tube or box?) The infill will follow the contour of a shape so if your object moves X,Y from layer to layer the infill will follow. You could also just make the shape in your 3D software but I know that's not as simple a solution.
Re: Honeycomb infill: first layer displacement December 25, 2013 06:04PM |
Re: Honeycomb infill: first layer displacement December 25, 2013 06:10PM |
Re: Honeycomb infill: first layer displacement December 25, 2013 06:17PM |
tmorris9
Here is a much closer look at just the first few layers of the cylinder object.
Re: Honeycomb infill: first layer displacement December 25, 2013 06:28PM |
Re: Honeycomb infill: first layer displacement December 25, 2013 09:54PM |
| FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
| Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Honeycomb infill: first layer displacement December 26, 2013 11:11PM |
Re: Honeycomb infill: first layer displacement December 26, 2013 11:27PM |
Re: Honeycomb infill: first layer displacement December 26, 2013 11:44PM |
Re: Honeycomb infill: first layer displacement December 26, 2013 11:52PM |
Re: Honeycomb infill: first layer displacement January 01, 2014 03:51PM |
Re: Honeycomb infill: first layer displacement January 01, 2014 04:25PM |
Re: Honeycomb infill: first layer displacement January 03, 2014 04:53AM |
Re: Honeycomb infill: first layer displacement January 03, 2014 10:44AM |
Re: Honeycomb infill: first layer displacement January 04, 2014 12:00AM |
Re: Honeycomb infill: first layer displacement January 05, 2014 11:22AM |
Re: Honeycomb infill: first layer displacement January 05, 2014 11:35AM |
Re: Honeycomb infill: first layer displacement January 05, 2014 11:39AM |
Re: Honeycomb infill: first layer displacement January 05, 2014 05:59PM |
