cannot slice this file
Posted by jon_bondy
January 20, 2014 01:38PM
Sketchup says the object is "solid" and NetFabb Studio basic says there are no problems, and Slic3r does not complain when slicing starts, but it crashes silently while generating perimeters.
open | download - test.stl (259 KB)
open | download - FIlament.ini (419 bytes)
open | download - Print.ini (1.8 KB)
open | download - Printer.ini (557 bytes)
Re: cannot slice this file
January 20, 2014 01:54PM
Reproduced, I can't slice it at full size, but can slice it when scaled down to 30%, maybe there's a bug where something grows to large or goes out-of-range when trying to process the full sized version?
Edit : Am using version 1.0.0RC1
Edited 1 time(s). Last edit at 01/20/2014 01:54PM by Azrael_UK.
Prussa i2 Comissioned 4-Nov-2013
Bitcoin : 1Jcrg5czBtNfKyS4sCjFAamJTcSYdTGk9h
January 20, 2014 03:04PM
When I measure the original, it is showing a size of 1000mm (1 meter) x 300mm (30cm)
So this could be considered rather large and explain why it is taking my machine a long time to slice it?
Was the original designed as SI, then when opened as metric, it shows up as huge?
January 20, 2014 03:53PM
Thanks for your help...
I design most of my parts as 10x or 100x (in mm) and then scale when I load the STL in Repetier Host. I have been doing this with RH/Slic3r for almost a year. I doubt that the size, alone, is the problem. I need to slice it at 1/10 the given size, and this is what is failing.
January 20, 2014 04:47PM
SLic3r will not slice anything that is bigger than the build plate. It says something like "Object will not fit on the build plate" and exits.
January 20, 2014 05:10PM
The object, after scaling, is not bigger than the build plate. I sliced and printed a variation on this a few hours ago. This variation will not slice. Slice3r gives up without a whimper.
January 20, 2014 05:22PM
I am using the release of Slic3r that was delivered with Repetier Host 0.95F
January 20, 2014 05:26PM
Using V1.0.0 R2 and scaling your model to 10% I can slice it with my settings no problem. I have not tried with your settings though.
January 20, 2014 06:02PM
Wish I knew a work-around. Like which slicing parameter is causing the problem, or which aspect of the model is causing the problem.
January 20, 2014 06:03PM
Perhaps if you posted your settings, I could try to see how they differ from mine
January 21, 2014 03:35AM
Here is my pref file that I normally start with and may edit it depending on the print. This is the pref I sliced it with and it worked.
open | download - Solid .25mm .35 nozzle.ini (2.7 KB)
January 21, 2014 05:39PM
Your slicing parmeters work here, so there must be something problematic with the slicing parameters that I was using. Still, Slic3r should have reported an error rather than just terminating.
January 21, 2014 05:55PM
I had to change Perimeters from 1 to 2. Strange that this caused such a serious bug, with no error message from Slic3r.
Edited 2 time(s). Last edit at 01/21/2014 07:05PM by jon_bondy.
