About 40% of the things I slice cause the printer to freeze after the first layer.
- It's repeatable. Some gcode will ALWAYS print, and some will NEVER get past the first layer or so.
- Sometimes changing a random setting in Slic3r will make something work (e.g. removing brim), but I can't find a pattern.
- Sometimes the same Slic3r settings used on different parts will work and sometimes not.
- I don't change temperature after first layer.
This occurs when I use both GCodePrintr (Android) and Octoprint (Linux). Repetier firmware running on an Azteeg X3.
Thanks for the insights folks!
