Reduce speed/acceleration for tiny/small infills
Posted by sedaka
May 21, 2014 11:07AM
Hi forums, need your help please!
On small infills with infill speed more than 40mm/s the printer makes strong vibrations. Because the infill length have just a few millimeters. How to reduce that? If I reduce the infill speed (at all), the print needs hours to be finished. I tried with "acceleration control (advanced)" but it will occur an error (division by zero). At printer setting "vibration limit" there will be no effect (tried 1,5,10 and 15 Hz).
Any ideas?
Best,
Sebastian
Re: Reduce speed/acceleration for tiny/small infills
May 21, 2014 12:50PM
got it! You have to fill out every field with a value higher 0 in the "acceleration control (advanced)" section :-)
30 mm/s2 is realy nice to see the difference than the default values :-)
