Slic3r takes forever to export to G-Code June 04, 2014 07:51AM |
Re: Slic3r takes forever to export to G-Code June 04, 2014 09:48AM |
Re: Slic3r takes forever to export to G-Code June 04, 2014 10:47AM |
Re: Slic3r takes forever to export to G-Code June 05, 2014 07:57AM |
Re: Slic3r takes forever to export to G-Code June 07, 2014 06:59AM |
Re: Slic3r takes forever to export to G-Code June 11, 2014 09:30PM |
Re: Slic3r takes forever to export to G-Code June 11, 2014 10:21PM |
Re: Slic3r takes forever to export to G-Code June 11, 2014 11:07PM |
Re: Slic3r takes forever to export to G-Code June 12, 2014 08:37AM |
isonoob
I hope it didn't come off as me thinking slicing time is the most important aspect of a slicing software. Indeed, at the end of the day, the most important thing is the reliability and quality of the G-Code generated, I only highlighted and talked about the speed of the two softwares because it is the nature of this particular thread.
Re: Slic3r takes forever to export to G-Code June 20, 2014 08:32PM |
Re: Slic3r takes forever to export to G-Code June 26, 2014 03:35AM |
Re: Slic3r takes forever to export to G-Code June 27, 2014 09:30AM |
Re: Slic3r takes forever to export to G-Code July 07, 2014 05:11AM |
Re: Slic3r takes forever to export to G-Code July 07, 2014 05:13AM |
Sardi
Without "avoid crossing perimiters" it works ok, couple of minutes to export.
With "avoid crossing perimiters" it does not export.
However, when I click "view" in Slic3r, I see that he somehow connected different poligons and faces, that are not connected in the original file. So something is very much off there.
In Cura I had no problems with exporting nor with the view or print of the g-code.
Re: Slic3r takes forever to export to G-Code July 09, 2014 01:07AM |
SunnyTurtle
Sardi
Thanks
unchecking "avoid crossing perimiters"
reduced my slicing time down from 46mins to 14seconds
EDIT
I tyred printing with multipliable items on the plate and it ripped one of them off. is there anyway to make slic3r object with out swapping from one to the other all over the shop.
