Slic3r and REPetier September 08, 2014 07:19AM |
12:46:55.351 : => Generating perimeters
12:46:55.369 : Error in function new_from_config_width at src\Flow.cpp:9: Invalid flow height supplied to new_from_config_width()
12:46:55.369 : at C:/PROGRA~1/Repetier-Host/Slic3r/lib/std/Slic3r/XS.pm line 126
12:46:55.369 : Slic3r::Flow::new_from_width('Slic3r::Flow', 'width', '100%', 'role', 0, 'nozzle_diameter', 0.1, 'layer_height', 0, ...) called at C:/PROGRA~1/Repetier-Host/Slic3r/lib/std/Slic3r/Print/Region.pm line 54
rint::Region::flow('Slic3r:
rint::Region=HASH(0x3d056f8)', 0, 0, 0, 1, undef, 'Slic3r:
rint::Object=HASH(0x3d00318)') called at C:/PROGRA~1/Repetier-Host/Slic3r/lib/std/Slic3r/Layer/Region.pm line 52
12:46:55.369 : Slic3r::Layer::Region::flow('Slic3r::Layer::Region=HASH(0x398f4e8)', 0) called at C:/PROGRA~1/Repetier-Host/Slic3r/lib/std/Slic3r/Print/Object.pm line 377
rint::Object::make_perimeters('Slic3r:
rint::Object=HASH(0x3d00318)') called at C:/PROGRA~1/Repetier-Host/Slic3r/lib/std/Slic3r/Print.pm line 416
rint::__ANON__(0) called at C:/PROGRA~1/Repetier-Host/Slic3r/lib/std/Slic3r/Print.pm line 388
rint::__ANON__(2, 'CODE(0x41c36b0)') called at C:/PROGRA~1/Repetier-Host/Slic3r/lib/std/Slic3r/Print.pm line 417
rint::process('Slic3r:
rint=HASH(0x3afd1a8)') called at C:/PROGRA~1/Repetier-Host/Slic3r/lib/std/Slic3r/Print/Simple.pm line 92
rint:
imple::export_gcode('Slic3r:
rint:
imple=HASH(0x3d0b1c8)') called at C:/PROGRA~1/Repetier-Host/Slic3r/lib/std/cavaexecscript/slic3r.pl line 180
12:46:55.370 : require cavaexecscript/slic3r.pl called at /Application::Loader line 1469
12:46:55.370 : Cava:
ack::Code::_run_packaged_script('cavaexecscript/slic3r.pl') called at /Application::Loader line 1496
ack::Code::_run_doscript() called at /Application::Loader line 1558
Re: Slic3r and REPetier September 10, 2014 09:18AM |
Re: Slic3r and REPetier September 10, 2014 06:36PM |
Re: Slic3r and REPetier September 10, 2014 10:20PM |
Re: Slic3r and REPetier September 11, 2014 10:26AM |
Re: Slic3r and REPetier September 12, 2014 04:19AM |
Re: Slic3r and REPetier September 15, 2014 01:39PM |
