what does "Extrusion Multiplier" do? October 04, 2014 06:49PM |
Re: what does "Extrusion Multiplier" do? October 04, 2014 11:06PM |
Re: what does "Extrusion Multiplier" do? October 05, 2014 03:47AM |
Re: what does "Extrusion Multiplier" do? October 06, 2014 02:16AM |
anon92
OK, so from my printer wiki I need to do some calibrations. First I made sure the motor which is pulling the filament in is moving the correct amount of steps per mm by following a guide from their wiki.
In the next page, I'm told also need to make sure the correct amount of plastic "is coming out as well", by printing a 1-layer thick wall, measuring its with with a caliper, then changing the "Extrusion Multitplier" in Slic3r by doing some calculation with that data.
I dont get it, what's the point?
Isn't changing the "extrusion multiplier" just talking the "Steps per mm" number which I've already calculated and entered in my software and multiplying it with the "Extrusion Multiplier" number from Slic3r settings and using the resulted number instead? Because if it is, then shouldn't there be no need for multiplying the number I've already calculated and I should just set the multiplier to 1?
What am I missing?
Re: what does "Extrusion Multiplier" do? October 06, 2014 03:26PM |
Re: what does "Extrusion Multiplier" do? October 09, 2014 06:45PM |
