Variable Z offset for multiple material printing
Posted by ben.ignis
November 18, 2014 11:36AM
I'm looking to print a shelled shape with a 2nd colour inner but can't work out how to programme Slic3r to do this - if I try to build an .amf file from separate .stl ones it automatically assumes the inner begins at the same level as the base of the shelled object. Is there a way of setting a Z offset for the 2nd .stl so that it sits on top of the inside of the shelled object?
Re: Variable Z offset for multiple material printing
November 25, 2014 02:10AM
Yes, with your second object selected, click "move object button" in the right panel and then you can place your x,y,z coordinate´s model. Fisrtable you can see the another model´s Zmax in the object properties panel, to place correctly the origin of your second model.
Sorry for my bad English.
