1.2.5 = crash on gear slicing
Posted by ZeAllan
January 23, 2015 09:41AM
I'm trying to use the new XY Size Compensation feature to get a set of gears the perfect size (not scale, more like designed size for the teeth to mesh properly). I've had a bit of luck with the feature in 1.2.5 on simple test objects (just a square with some holes in it), which look very promising -- but every time I try something more complex, the slicing process crashes.
The file big_gear_top_M5.stl from [www.thingiverse.com] is one example. Netfabb finds no problems in the file, and older 1.1 versions of Slic3r work fine (just makes it a bit too large on the outside and with too small a hole to fit on the axis). However, 1.2.5 will crash. While waiting for 1.2.6, is there some some simple setting that will make 1.2.5 work also?
Re: 1.2.5 = crash on gear slicing
January 23, 2015 11:36AM
1.2.5 IS an experimental version. Did you try the stable version: 1.1.7?
January 23, 2015 12:34PM
1.1.7 works -- but XY Size Compensation is a new feature in the 1.2 series.
January 23, 2015 02:42PM
I think they are hoping to release a stable 1.2.x soon. Maybe it will address your issue
