I'm trying to use the new XY Size Compensation feature to get a set of gears the perfect size (not scale, more like designed size for the teeth to mesh properly). I've had a bit of luck with the feature in 1.2.5 on simple test objects (just a square with some holes in it), which look very promising -- but every time I try something more complex, the slicing process crashes.
The file big_gear_top_M5.stl from [
www.thingiverse.com] is one example. Netfabb finds no problems in the file, and older 1.1 versions of Slic3r work fine (just makes it a bit too large on the outside and with too small a hole to fit on the axis). However, 1.2.5 will crash. While waiting for 1.2.6, is there some some simple setting that will make 1.2.5 work also?
