Bad 'grinding' noise at the start of every print eye popping smiley
Posted by Garry Bartsch
March 16, 2015 02:30PM
When I start a print my Mendel90 makes a very brief 'grinding' sound (sounds like 'grrrkk') just as the X carriage begins it's descent from homing at the top. It's a split second long but very disconcerting! Happens every time. This is Slic3r 1.2.6 experimental x64. It doesn't happen in version 1.1.7 stable. It also doesn't happen when I slice with a different slicer.
Any ideas what might cause this sound?
New browser from the creator of Opera: [vivaldi.com]
Re: Bad 'grinding' noise at the start of every print eye popping smiley
March 24, 2015 01:46PM
I used to get something like that from the starting gcode "G1 Z5 F5000", where G means move, Z5 is the coordinate, and F5000 means lightspeed. I do not have hyperdrive capable thrusters on my threaded rods, and so, the mundane stepper motor would skip when it attempted F5000. I now have it set to "G1 Z0.35 F100" and I don't have the problem any longer.
This, however, is a superficial solution, and I should really go into the firmware and change the max speed for my axes.
Perhaps try diving into your gcode and change all the F values which are before the X carriage descent and see whether that changes your problem.
In the expert mode of Slic3r you have the option to change the start gcode.
March 24, 2015 06:27PM
It's funny. The machine is not exhibiting this behavior now. It suddenly just stopped and I haven't felt like testing other versions of Slic3r or other slicers to try to repeat the problem. 1.2.6 us working very well. So when I have more time I will test other slicers but for now all is good.
