Printing Sequential Replicates with Different Settings March 20, 2015 12:47PM |
Re: Printing Sequential Replicates with Different Settings March 21, 2015 03:12PM |
Re: Printing Sequential Replicates with Different Settings March 24, 2015 01:59PM |
Re: Printing Sequential Replicates with Different Settings March 24, 2015 02:17PM |
IMBoring25
You don't mention what version you're using, but the experimental branch of Slic3r does currently support this.
Under Print Settings, then Output Options there's a checkbox for Complete Individual Objects, which will print the objects sequentially, and then the only thing you have to manually modify in the G-code would be to input the temperature-change commands each time Z goes back to the first layer height. Do make sure you set the extruder clearance values correctly to prevent collisions with already-built parts.
For speeds, infills, retraction values, and such it's even easier, and you don't need to print the objects sequentially. Lay out your plate, then click a part you want to vary from default settings, then right click on it and choose Settings. From there, you can choose alternate extruders or use the plus in the lower section of the window to add specific settings to change.
That's why I was talking about sequential printing, i.e. the printer will finish the first object, change temp, then start the next one and finish it, to the next..... and so on. This way there would only be 4 temp changes in your example.Quote
kre8
Under the Plater tab, when you have one of the objects on your plate selected, you can click Settings to choose specific settings for only that object. The thing is, it's pretty silly to try and print objects side-by-side at different temperatures, because the hotend would have to change temperatures four times every layer, the print would take forever, and the nozzle would drool like crazy as the temperature changes were happening.
