Strange outstanding perimeters March 30, 2015 05:07PM |
Re: Strange outstanding perimeters March 31, 2015 03:37AM |
Re: Strange outstanding perimeters March 31, 2015 03:59AM |
Re: Strange outstanding perimeters March 31, 2015 09:19AM |
Re: Strange outstanding perimeters March 31, 2015 10:33AM |
Re: Strange outstanding perimeters March 31, 2015 02:56PM |
Re: Strange outstanding perimeters April 01, 2015 06:23AM |
Re: Strange outstanding perimeters April 01, 2015 07:33AM |
NitroXpress
Hi Falk,
indeed it is a interaction of many slicing and firmware settings.
For this model CURA is the better choice, because the higher slicing resolution and more precise extrusion calculation, also depending on model resolution.
A worse model/slicing resolution causes acceleration/deceleration peaks.
For a smooth surface it is important to have a steady trajectory generation.
You can counteract with lowering your acceleration settings.
This causes less pressure peaks in the extruder.
Of course this extends printing time, but gives much "softer" moves.
Frank.
Re: Strange outstanding perimeters April 01, 2015 07:52AM |
Re: Strange outstanding perimeters April 01, 2015 09:45AM |
Re: Strange outstanding perimeters April 01, 2015 10:40AM |
NitroXpress
As you can see, 150mm/sec gives perfect surface quality.
With 60mm/sec you can see the created segments from the slicer.
Frank
Re: Strange outstanding perimeters April 01, 2015 10:54AM |
Re: Strange outstanding perimeters April 01, 2015 11:03AM |
