Printer extrusion off by 10mm to Slic3r. April 06, 2015 03:32AM |
Re: Printer extrusion off by 10mm to Slic3r. April 06, 2015 11:36AM |
Re: Printer extrusion off by 10mm to Slic3r. April 07, 2015 09:22AM |
IMBoring25
Even with a closed firmware there should be some way to recalibrate the extruder. Passing gcode M503 should show if your EEPROM is setting your steps per mm. Failing that, you could use a 1.25 extrusion multiplier in Slic3r.
