Slic3r wont open STL
May 28, 2015 04:42PM
A threaded part I created wont open in Slic3r but opens fine in Kisslicer and Cura. Skeinforge fails as well.
Meshlab and netfabb say there are no errors and when exporting the STL from Cura that file opens and slices just fine in Slic3r.
The Cura stl file is about 1/6 of the original file size so there seem to be something removed that Slic3r has a problem with.
Any workarounds to avoid Cura?
The part was created in Sketchup and the problem also appears when trying to open the thread only.
Re: Slic3r wont open STL
May 30, 2015 06:51AM
Noone can help you without seeing the original STL file.
May 30, 2015 07:29AM
Stl attached, printing the cura converted file as we speak. The original file was too large to attach.
Edited 1 time(s). Last edit at 05/30/2015 08:03AM by hsbontop.
open | download - Adapter.stl (277.4 KB)
May 30, 2015 03:23PM
hsbontop
If that's the version from Cura, it's of no use.
That file opened just fine in 1.2.8-dev though.
If the file is too big, link it from a dropbox, onedrive, google drive or whatever place.
Edited 1 time(s). Last edit at 05/30/2015 03:25PM by Mikk36.
May 30, 2015 05:47PM
Link attached, stl printed just fine (pitch on the thread a bit too narrow though).
Original stl
June 01, 2015 03:09AM
hsbontop
Original stl
I see no issue with my Slic3r here even with the original file.
June 01, 2015 08:06AM
You can use WinRar to ZIP or RAR files that are too large to attach, and enter the max. file size option so that it splits to multiple parts. Then attach each part separately.
Dave
June 01, 2015 02:51PM
Had to start a new account on my computer as slic3r does not like Swedish letters (åäö) and the administrator account contains one of these which makes saving of settings impossible. That made me wonder if this could be the reason here as well and embarrassingly enough I had renamed the cure converted files without the ä whereas the original file contained that letter. Now everything works fine, thanks for the effort! Have to print another one though as I managed to get the thread the wrong way around, measure once print twice...
June 04, 2015 04:11PM
Latest versions from github should resolve this unicode character issue.
