Cross line raft
Posted by oz
oz
Cross line raft
July 22, 2015 08:51AM
Is there any chance to make raft line 90 degree crossing previous raft layer. Just now im testing version 1.2.9.
I can set raft linear, reclinear, honeycomb or pillar, but there is no difference, except honeycomb, which sets at last 2nd layer from 3 in different direction.
I have overwrited previous version folder, could it be that problem, or there is just not crossing pattern raft?
Re: Cross line raft
July 23, 2015 12:35AM
You should have a pattern option for "rectilinear grid," which will alternate direction from one layer to the next.
oz
Re: Cross line raft
July 23, 2015 05:17AM
As i say before, selecting "reclinear grid" or "pillars" makes no defference from "reclinear", raft layers are always in same direction... :0(
Only if i select 3 or more "pattern layers" i can see som crosslines on "patern raft layers", but interface layers are always in same direction and if i select less layers , for example 1 massive grid on table with 2,5mm spacing and then 1 interfece layer with 0.5mm spacing, i always get lines in same direction...
Edited 3 time(s). Last edit at 07/23/2015 05:33AM by oz.
Re: Cross line raft
July 23, 2015 08:19AM
I have noticed this also. The first two raft layers are in the same direction and so the second layer doesn't necessarily get proper support. All interface layers are in the same direction as the first raft layer. I reported it as an issue on github.
