Slic3r prints 2 layers on the same layer height August 25, 2015 07:42AM |
; generated by Slic3r 1.2.9 on 2015-08-25 at 13:27:02 ; external perimeters extrusion width = 0.50mm ; perimeters extrusion width = 0.50mm ; infill extrusion width = 0.50mm ; solid infill extrusion width = 0.50mm ; top infill extrusion width = 0.50mm M190 S108 ; set bed temperature M104 S240 ; set temperature G28 Y ; G28 X; G28 Z; G1 Z2 F5000; G1 Z5 F5000 ; lift nozzle M109 S240 ; wait for temperature to be reached G21 ; set units to millimeters G90 ; use absolute coordinates M82 ; use absolute distances for extrusion G92 E0 M106 S255 //LAYER CHANGE G1 E-1.00000 F1800.00000 G92 E0 G1 Z-1.130 F1800.000 G1 X-0.674 Y-0.501 F1800.000 G1 E1.00000 F1800.00000 G1 X-0.132 Y-1.232 E1.03805 F1440.000 G1 X1.505 Y-2.139 E1.11627 ........... G1 X5.441 Y20.603 F1800.000 G1 E1.00000 F1800.00000 G1 X5.380 Y21.637 E1.09182 F480.000 G1 X5.441 Y22.574 E1.17505 //LAYER CHANGE G1 E0.17505 F1800.00000 G92 E0 G1 Z-1.130 F1800.000 G1 X38.063 Y19.064 F1800.000 G1 E1.00000 F1800.00000 G1 X52.263 Y19.064 E1.59349 F960.000 G1 X52.263 Y27.864 E1.96130 ....................... G1 X29.558 Y62.245 F1800.000 G1 E1.00000 F1800.00000 G1 X29.578 Y62.712 E1.04136 F480.000 G1 X29.578 Y65.256 E1.26677 M104 S233 ; set temperature M140 S92 ; wait for bed temperature to be reached //LAYER CHANGE G1 E0.26677 F1800.00000 G92 E0 G1 Z-0.830 F1800.000 G1 X25.763 Y31.867 F1800.000 G1 E1.00000 F1800.00000 .................... G1 X65.918 Y39.509 E7.52758 G1 X65.693 Y39.733 E7.53371 //LAYER CHANGE G1 E6.53371 F1800.00000 G92 E0 G1 Z-0.830 F1800.000 G1 X61.245 Y59.725 F1800.000 G1 E1.00000 F1800.00000 ........................ G1 X27.607 Y39.334 F1800.000 G1 X28.175 Y38.641 E3.40572 F1200.000 //LAYER CHANGE G1 E2.40572 F1800.00000 G92 E0 G1 Z-0.530 F1800.000 G1 X38.784 Y19.790 F1800.000 G1 E1.00000 F1800.00000
Re: Slic3r prints 2 layers on the same layer height August 26, 2015 11:52AM |
Re: Slic3r prints 2 layers on the same layer height August 26, 2015 01:40PM |
dmould
Odd. I've never come across a negative Z value being commanded. It the STL flush with the bed in the plater window?
Re: Slic3r prints 2 layers on the same layer height August 27, 2015 07:37AM |
dc42
dmould
Perhaps he has a negative Z offset configured in slic3r?
Re: Slic3r prints 2 layers on the same layer height August 27, 2015 09:29PM |
Re: Slic3r prints 2 layers on the same layer height August 31, 2015 02:28PM |
M109 S240 ; wait for temperature to be reached G21 ; set units to millimeters G90 ; use absolute coordinates M82 ; use absolute distances for extrusion G92 E0 ; reset extrusion distance M106 S255 ; enable fan G1 E-1.00000 F1800.00000 ; retract G92 E0 ; reset extrusion distance G1 Z0.400 F2400.000 ; move to next layer (0) G1 X22.194 Y59.939 F2400.000 ; move to first skirt point G1 E1.00000 F1800.00000 ; unretract G1 X24.131 Y59.436 E1.09303 F450.000 ; skirt G1 X72.887 Y55.827 E3.36526 ; skirt G1 X73.300 Y55.812 E3.38444 ; skirt G1 X64.987 Y85.350 E1.18033 ; infill G1 E0.18033 F1800.00000 ; retract G92 E0 ; reset extrusion distance G1 Z0.400 F2400.000 ; move to next layer (1) G1 X47.104 Y84.649 F2400.000 ; move to first perimeter point G1 E1.00000 F1800.00000 ; unretract G1 X56.954 Y84.649 E1.45779 F840.000 ; perimeter G1 X56.954 Y85.769 E1.50985 ; perimeter G1 X24.984 Y85.769 E2.99570 ; perimeter M104 S233 ; set temperature M140 S100 ; wait for bed temperature to be reached G1 E0.51508 F1800.00000 ; retract G92 E0 ; reset extrusion distance G1 Z0.700 F2400.000 ; move to next layer (2) G1 X74.421 Y85.229 F2400.000 ; move to first perimeter point G1 E1.00000 F1800.00000 ; unretract G1 E0.06631 F1800.00000 ; retract G92 E0 ; reset extrusion distance G1 Z0.700 F2400.000 ; move to next layer (3) G1 X37.003 Y70.785 F2400.000 ; move to first perimeter point G1 E1.00000 F1800.00000 ; unretract
Re: Slic3r prints 2 layers on the same layer height September 01, 2015 08:14AM |
Re: Slic3r prints 2 layers on the same layer height September 01, 2015 01:46PM |
