Variable infill
Posted by RRuser
Variable infill
August 27, 2015 05:32AM
I've checked, and I don't think there is a way to have different infill amounts/percentages on different Z heights the way you can have different layer thicknesses.
Is this correct?
Re: Variable infill
August 29, 2015 02:55AM
Use modifier objects.
Re: Variable infill
August 29, 2015 01:52PM
Good idea.
I can get the modifier loaded, but is there a way to place it in relation to the main object? When I try moving it, it snaps back to some original spot.
Re: Variable infill
August 29, 2015 05:57PM
You need to not have the exporting program center the part towards the 0,0 point when you export your object to the STL file. For example, in Solidworks, there's a checkbox like this: "Do not translate output data to positive space"
This makes sure that everything stays in the same space (ie, where YOU want them to) even when you export multiple different objects of different shape and size.
Slic3r uses this information to place the modifier objects in the correct place.
Edited 1 time(s). Last edit at 08/29/2015 05:58PM by Mikk36.
