Support Material Vertical Spacing
September 23, 2015 05:09PM
I'm pretty new to using support material, most things I print don't require it. I'm trying to print something that has a 90* cantilever overhang, but when I use the default support settings and I remove the support material the print quality is fairly poor. It seems as though slicer is leaving space between the support material and the structure itself. How do I close this gap? Thanks!
Re: Support Material Vertical Spacing
September 24, 2015 12:54AM
print settings>support material>contact Z distance - make it smaller by typing a value over the default 0.2 mm
September 24, 2015 08:17AM
Wow, I don't know how I overlooked that. Thanks!
September 24, 2015 10:42AM
If you make it too small however, it will be difficult to remove the support material.
Dave
