holes are too small
Posted by strawmedia
holes are too small
September 25, 2015 11:58AM
Hello smiling smiley
I wanted to print a ramps to melzi Mount, but somehow all of the holes are too small to fit an m3 screw, but they have a radius of 2mm. I printed a 2cm test cube and everything was fine.
Printer : i3 variant with 0.4mm nozzle and 1.75mm Filament Diameter
Print Settings : 1.75mm Filament Diameter ; Extrusian Multiplier : 1 ; Hotend Temp : 200C ; Bed Temp : 60C ;
Layer Height : 0.2mm ; First Layer : 0.3mm ; 3 vertical and horizontal Shells ; Not printing external Perimeters first.
I tried printing a 10mm hole, it came out as ~9.5mm
Any suggestions? Thanks smiling smiley
Straw
Re: holes are too small
September 25, 2015 01:41PM
This is a well-known problem and there are lots of existing threads about it. I find that checking "External perimeters first" makes the holes come out closer to the correct size, but still too small.
Either print some parts containing calibration holes so you can work out what hole size you need to ask for to get the size you want, or use a drill to ream out the holes to the correct size. You need a 3mm drill for an M3 screw clearance hole, a 2.5mm drill for a M2.5 screw, and so on. A 2.3mm drill is good for a hole that an M2.5 screw will tap into.
September 25, 2015 04:36PM
@dc42 is this Problem stil appearing in other slicer Software, like skeinforge or cura? or is there any other slicer which doesnt has this Problem but still offers many Options like slic3r does?
Thanks
~Straw
September 26, 2015 02:46AM
I think you'll find it will happen with any slicer - its a mechanical issue. The problem is that when you are printing a small hole - as the nozzle is traveling around the circle - the filament is being pulled toward the center, making the hole smaller.
As dc42 suggested, you could print a Hole Calibration Test Block
September 27, 2015 07:38AM
In time You'll learn to compensate for slightly too small holes already when designing the parts.
