Dense Support material is added between two parralel horizontal surfaces September 30, 2015 08:05AM |
Re: Dense Support material is added between two parralel horizontal surfaces September 30, 2015 08:24AM |
Re: Dense Support material is added between two parralel horizontal surfaces September 30, 2015 08:28AM |
Re: Dense Support material is added between two parralel horizontal surfaces September 30, 2015 08:31AM |
Re: Dense Support material is added between two parralel horizontal surfaces September 30, 2015 08:41AM |
Re: Dense Support material is added between two parralel horizontal surfaces September 30, 2015 08:49AM |
Re: Dense Support material is added between two parralel horizontal surfaces September 30, 2015 08:53AM |
Re: Dense Support material is added between two parralel horizontal surfaces September 30, 2015 09:25AM |
Re: Dense Support material is added between two parralel horizontal surfaces September 30, 2015 09:30AM |
Re: Dense Support material is added between two parralel horizontal surfaces September 30, 2015 09:51AM |
Re: Dense Support material is added between two parralel horizontal surfaces September 30, 2015 10:10AM |
Re: Dense Support material is added between two parralel horizontal surfaces September 30, 2015 11:45AM |
Re: Dense Support material is added between two parralel horizontal surfaces September 30, 2015 03:44PM |
Re: Dense Support material is added between two parralel horizontal surfaces September 30, 2015 06:41PM |
Re: Dense Support material is added between two parralel horizontal surfaces October 01, 2015 09:46AM |
Re: Dense Support material is added between two parralel horizontal surfaces October 01, 2015 10:28AM |
Re: Dense Support material is added between two parralel horizontal surfaces October 01, 2015 10:55AM |
Re: Dense Support material is added between two parralel horizontal surfaces October 01, 2015 11:06AM |
williamr
Although you can't cut at a specific Z directly you can either see by looking from the top at a specific angle or edit the gcode directly using Tools>Edit and remove some GCode to erase the top of the print to see as you would see during a print => then indeed you can see that it's a slicing issue because the infill is really dense.
But I'm sure there exists tools that allows to view GCode and not render some specific layers, but I don't know them.
Re: Dense Support material is added between two parralel horizontal surfaces October 01, 2015 11:10AM |
