I have a slic3r problem. I need to generate g-code for two models that has to be aligned and with different fill densities. I mean I have to print 1 model with different parts of the print with different fill density. See image.
With slic3r GUI when I add both of the models separately alignment is not correct. But when I add one model first and then second model through first models settings - the alignment works perfectly. And I can even give these STLs different infill values.
My question is: Does anyone know a way of doing this same thing with slic3r-console (terminal)?
I have tried the Slic3r from the terminal with command: "./slic3r -m in.stl --fill-density 10% out.stl --fill-density 90%" the different infills are not working and the models are auto centered to wrong positions.
thanks,
Petja
ps. Using slic3r 1.2.9 on Ubuntu 14.04
